Question about Jenn-Air JMC7000 Microwave Oven
I need to replace a Jenn-Air 1.3 cu. ft. model M169W 22" WIDE microwave, part of a combo/oven unit. What type will slide in How about the LG : LMV1314W 1.3 cu. ft. Compact Over the Range Microwave - White? . I'm thinking the
MicrowaveSvc
  • 9098 Answers
SOURCE: Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Removing a built in Jenn-Air Microwave from it cabinet...
First of all, what are the symptoms? Please reply back and I'll be happy to share my thoughts.
Many parts can be accessed without removing the oven from the wall by just removing the control panel.
You need to be sure the cord is unplugged, then you remove the vent grille that runs across the top.
Then you'll see a screw holding the control panel in place. Once that screw is out, you can lift out and out carefully to separate the control panel form the chassis.
If you pull any wires off the control panel, mark and/or photograph them first to be sure you get them ALL back in the right place.
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Before you start, we have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
While they don't have their installation instructions online, the owner's manual is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
  • 52 Answers
SOURCE: Recommended clearance from bottom of microwave to range top
Your installation manual should have given specific height limitations. I'm not sure for your model, but I beleive it's no less than 22". If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 29, 2009
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
heatman101
  • 43501 Answers
SOURCE: Jenn Air Microwave M169W will run but not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
zcvzcv
Posted on Sep 30, 2010
Jenn-Air M170 Microwave Oven "dimensions
http://kitchen.manualsonline.com/manuals/mfg/jennair/m170.html
Toll free 800 number and email for support.
https://www.justanswer.com/appliance/6r6z4-dimensions-jenn-air-m170-built-in-microwave.html
Link above states:
What are the dimensions of the Jenn-Air M170 built-in Microwave...
What are the dimensions of the Jenn-Air M170 built-in Microwave Oven (built 1998) that I need to specify for a replacement unit? Externally, I see the frame measuring 26 3/4" W by 17" H, and the unit within the frame measuring 22" W by 13" H.
Share this conversation
Answered in 1 hour by:
6/5/2012
Appliance Technician: Ed Michaels
Ed Michaels : Hi, your machine is long out of production and installation instructions usually come with the machine and are not published. you have a standard size 24" built in machine, and most 24" machines will fit the space. I would click on Jenn Air or call 1-800-JENN-AIR (536-6247) and ask for a replacement recommendation and a copy of old installation instructions for planning with designer or installer. They have access to records if anyone does and an interest in serving you. Alternatively, talk to another seller and discuss installation. they will also want to help. Let me know if I can help further.ed
Mar 08, 2018 | Jenn-Air Microwave Ovens
What is the CU. Ft. for Jenn-Air Micro M437
Here is a link to a psf og the user manual for that oven:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20164D2588PO12.pdf
Sep 09, 2014 | Jenn-Air Microwave Ovens
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profileā„¢ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
Hi, I have a Jenn Air microwave oven Model M169W that a repair shop has not been able to repair. It quits heating after 7 or 8 times of use.What is the problem? A new control board and magnatron have been...
The pros cant fix it? Your expectation is high, evidently!
I would presume they checked the cap output and the door switches. Can you verify they did these two very important checks?
If you are unsure, you could check the door interlock safety switches yourself.
Beyond that, I am frankly afraid of getting a no thumbs up rating on this answer so I will not go any further.
Oct 16, 2009 | Microwave Ovens
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
heatman101
zcvzcv
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Jan 04, 2009 | Jenn-Air JMC8130DD Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
385 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
