Question about Euro-Pro Shark 9110 Sewing Machine
My dog ate the foot pedal that was attached to the power cord. Where can I get a new one?
    Novelist:
  • 233 Answers
Did he eat the homework too? Sorry, couldn't help it~ try going to this link. http://www.sew4less.com/product/4710/Foot_Control_with_Cord_and_Wire_4C_337GS_141000948_74998_74990_81495__Click_for_model_info. Their customer service number is at the top of the screen. Give them a call to be sure this foot will fit your machine before you order, because it's not completely specific on the screen. But when I pulled up for your model number within their search parameters, it led me here.
Posted on May 21, 2011
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Pneumatic air foot petal
If the machine won't work with two pedals that are good then the problem isn't the foot pedal. Does the light turn on? If this is functional then you know there is "electricity" attached to it. Since both pedals aren't functional you will have to have the motor and connecting cord (inside machine) to see which is the problem. By the way; if the problem is the cord inside the machine you may not want to plug it in. You stand a chance of getting shocked. Have it checked for safety.
Sep 27, 2016 | Sewing Machines
Where can i order a foot pedal
Carolyn, Google search your make and model# foot pedal. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sewing Machine Foot Pedal eBay
Sewing Foot Controls SewingMachinesPlus com
http://www.sewingmachinewarehouse.com.au/machine-accessories-feet-needlesglobesspare-parts/foot-pedals-and-power-cord
http://www.a1sewingmachine.com/parts.html
Jul 23, 2016 | Sewing Machines
How can I unplug the cord of the foot pedal without breaking it?
In my experience they all come with the cord attached to the foot pedal and you plug one wire into the mains outlet and the other lead into the sewing machine. You should be swapping like for like, so if your has a hard wired lead, then the replacement should too.
If you unscrew the screws on the foot pedal, you should be able to see if it is hard wired or the wire is in a socket. If it won't come out, it is possible it has got hot and melted the plastic to lock it in place.
Feb 04, 2016 | Sewing Machines
Wiring a foot control pedal for Singer 2010
Your question is not clear to me. If you need to work on the Foot Pedal I'd just buy a new one on eBay.
SPEED CONTROL FOOT PEDAL POWER CORD SINGER 7350 1 3709 3722 6510 2010...
Mar 26, 2015 | Singer Sewing Machines
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
Foot pedal doesn't work when pressed
you can either have that foot pedal checked or buy a new one
sewing machine parts
sewingpartsonline.com
sew4less.com
sewusa.com
premiersewing.com
ebay
Apr 12, 2012 | Sewing Machines
My machine beeps and will not sew when the foot peddle is pushed. i checked the BH lever inside the light cover and the small black switch appears to be in the up position. any other ideas?
make sure the foot pedal cord is pushed in correctly
rethread the machine top & bobbin
clean under the needle plate where the feed dogs are for lint
also clean the bobbin are for lint or loose threads
change needles
but also the foot pedal could have gone out
Nov 19, 2010 | Singer 7422
Singer 7462 sewing machine
There is two seperate cords on this machine. A power cord and a pedal cord. If you put the power cord in and switch the machine on, and then remove the pedal cord it should give you a beeping sound, which shows you the connection does work.
Please give me feedback in order to help you
Dec 08, 2007 | Singer 7462 Mechanical Sewing Machine
Euro-Pro Shark 9110 Sewing Machine Logo
35 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
