Question about Evenflo Triumph 5 Comfort Touch
I want to wash the cover. How do I detach the straps so that i can remove it?
  • 3 Answers
You need to unscrew the 6 screws on the back panel of the car seat and then pull it off. then their is two little white clips over the metal brackets that hold the straps on! just lift one end of the white clip and lift off. then take the metal bracket and pull a little toward the back of the seat and turn sideways, push through the hole! its easy once you get the back panel off! the same way if you were changing the height adjustment....
Posted on Aug 16, 2008
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How to change fuel pump on 2002 jaguar x-type
Full instructions are too detailed for this forum I will try and post it on http://www.bluejag.co.uk in the near future for you.
but briefly
you first need to remove the Fuel tank
then the pump
Disconnect Battery
Drain fuel tank if possible.
Remove filler cap
Remove rear seat cushion
Detach Wiring harness
Remove rear subframe
Detach Filler
Disconnect filter
Disconnect purge pipe
Disconnect evap emisions hose
Remove fuel tank support strap retaining bolts
Remove tank
then
Disconnect electrical connector
Remove Locking ring using Jaguar tool 310-072A
Remove transfer pump
Dec 04, 2010 | 2004 Jaguar X-Type
Remove and replace drivers door 1999 taurus?
Please don't forget to rate! Thank you!
Removal & Installation
The door-to-body mounting
Detach the door wiring from the connector
This is a two person operation.
  1. Remove the two door check-to-body retaining screws.
WARNING
Cover the end of the check strap to prevent possible paint damage.
  1. On the rear doors, remove the rear door trim panel, detach the electrical connectors from the components (if equipped) and remove the wiring harness from rear door.
  2. On the driver's side front door, disconnect the window regulator wiring, if so equipped, by removing the wire connector cover, loosening the screw and separating the connector halves.
  3. On the passenger side front door, remove the rubber harness protector from the body to reveal the electrical connectors. Detach the two electrical connectors.
  4. If the door is to be replaced, transfer the following components to the new door if in usable condition:
    • Door trim panel
    • Watershield
    • Outside mouldings
    • Trim clips
    • Window regulator
    • Door latch components.
  5. Remove the hinge retaining screws and nuts from the door and remove the door.
To install:
  1. Position the door onto the hinges and hand tighten the screws.
  2. Align the door and tighten the screws to 19-25 ft. lbs. (25-35 Nm).
  3. If removed, install the wiring harness to the rear doors.
  4. Attach the electrical connectors to the door panel.
  5. Install the door panel(s).
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 31; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Nov 20, 2010 | 1999 Ford Taurus
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
Feb 16, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
How to replace a heater core
CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Disconnect the negative battery cable and drain the cooling system.
  2. Raise and support the vehicle safely.
  3. If equipped, remove the rear lateral transaxle strut mount.
  4. Disconnect the drain tube from the heater case.
  5. Detach the heater hoses from the heater core.
  6. Carefully lower the vehicle.
  7. Remove the right and left sound insulators.
  8. Unfasten the steering column opening filler. Disconnect the heater outlet deflector (floor air outlet duct).
Disconnect the floor air outlet duct
Remove the heater core cover.
Unfasten the retaining bolts, then remove the heater core cover
Detach the heater core retaining straps (clamps), then remove the heater core.
Detach the retaining clamps or straps, then remove the heater core
To install:
  1. Install the heater core and retaining straps (clamps).
  2. Install the heater core cover.
  3. Reconnect the heater outlet deflector (floor air outlet duct).
  4. Install the right and left sound insulators. Install the steering column opening filler.
  5. Raise and support the vehicle safely.
  6. Connect the heater hoses (use new heater hose clamps if necessary) to the heater core.
  7. Connect the drain tube to heater case.
  8. Connect the rear lateral transaxle strut mount, if equipped.
  9. Lower the vehicle.
  10. Fill the cooling system and check for leaks. Check heater system for proper operation.
Nov 13, 2009 | 1994 Chevrolet Cavalier
Can I take off the cover and straps of to wash?
Yes you can remove the cover, but I would suggest that you leave the harness on. This can be a little tricky to remove, but can be done.
I hope this helps.
Nov 07, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
HOW DO THE STRAPS GO BACK THROUGH THE LATCHES? WE WASHED THE SEAT COVER AND WE CAN'T FIGURE OUT HOW THE STRAPS WERE THREADED TO LATCH THE BABY IN THE SEAT
Your not suppose to wash the cover...as bad as it sounds you are suppose to spot clean only... after you remove the cover their not safe any more.
Sep 23, 2009 | Eddie Bauer 3-In-1 with Latch
Britax eclipse
Try Britax.co.uk, they have all the user guides and instructions available for free download. i had the same problem as i washed the seat covers and then couldn't remember how to put the harness back. Hope that Helps.
Jul 16, 2008 | Britax Eclipse Si - Paris Convertible Car...
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Evenflo Triumph 5 Comfort Touch Logo
305 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
