Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Lights come on for two seconds then turn off - Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Check that wire is attached firmly to A and B terminals.
Check that outlet does not have loose wire.
Tripper might be worn down so it does not fully push the on-off lever.
Push tripper all the way down so it will contact the on-off lever.
Check that lights work with override switch.
If lights turn on-off with override, then set timer to ON, buy cheap plug-in timer, and plug power pack into cheap timer.
Generally, there is not good news if power pack stopped working.
Trippers can be replaced, but there are no repair parts for power packs.
Following link has troubleshoot checklist and replacement tripper information, and 5-year warranty info:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 21, 2011
How can I turn off the rear parking lights
Normally all parking lights are controlled by the light switch. First turn turn on the parking lights and second turn turns on the head lights.
Are you sure it is not your break lights staying on? if this is your break lights - look at break pedal for break light switch staying on or not adjusted correctly. Does your car battery gets drained from your break lights staying on?
Feb 23, 2015 | 2011 Cadillac SRX
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
I have two LED color lights in my pool. 1 changes color but the other does not
Your post did not specify the brand of pool lights you have, but assuming they are Hayward, it sounds as though the lights are out of sync... that is, one light is running a different program than the other. If both lights are controlled by the same on/off switch, this is a simple fix; If they are on separate switches you would use the same procedure, but then BOTH SWITHES must be toggled AT THE SAME TIME. To re-sync your lights, turn both lights on and, if necessary, wait for the15-second full-white period to elapse. Next, turn both lights off and wait no less than eleven (11) seconds, but not more than fourteen (14) seconds before switching the lights back on again. Remember... if each light is controlled by a separate switch, then both switches must be toggled "on", "off" and then "on" again at EXACTLY the same time. If the lights are operated in this sequence within the 11-14 second window, they will both automatically revert to full-white light for 15 seconds and then reset to program one. From that point on, as long as you switch the lights on and off at the same time (to cycle through the color programs), they will remain in sync. Good luck.
Dec 13, 2010 | Hayward 12v LED Color Logic Pool Light...
I am unable to reset the admin password on a company printer HP laserjet p2015dn. I treid doing a cold reset by holding the go button while restarting the printer for about 10 seconds and the configuration...
Try to change the password over the network by tyoing the assigned IP address into your browser URL. If you can see the P2015, you should ba able to find the place to change or disable the admin password. If not, perform a Super NVRAM Initialzation:
  1. Turn off the HP Laserjet P2015 Printer.
  2. Press and hold the Go button.
  3. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process, the Attention, Ready, Go lights turn on. Then the Attention and Ready lights turn off,leaving only the Go light illuminated.
  4. Release the Go button. The Go, Ready and Attention lights turn on.
  5. Press and hold the Go button. All lights turn off. During the next three seconds, the Go, Ready and Attention lights turn on in that order, one per second.
  6. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
May 02, 2010 | HP LaserJet P2015dn Printer
Flashing lights
sounds like you have a after market alarm that is not connected to a siren. so you get the flashing lights. what you need to do is locate the alarm brain usally under the dash near the steering colunm and unplug it. this will correct your problem.
Mar 24, 2010 | 1997 Subaru Outback
1996 Geo Metro - when the head lights are turned on the the engine idles up and down. As long as the lights are off, everything works fine. RPM's go up to about 2000 for a couple of seconds and then back...
Sounds like you may have a faulty switch, or bad ground in the system. This will cause the fluctuating idle when additional load is applied to electrical system.
Oct 17, 2009 | Geo Metro Cars & Trucks
Maintence light is blinkin when i start my car
Generally, the maintenance light should come on for a few seconds, then go off after the car has started. All of the dashboard warning lights do this so driver can tell they are operational. (Should see brake light, low oil pressure, airbag warning, etc. Any of the lowly "idiot" lights should come on.)
As a test, turn the key on, but not to start. All of the lights should flash on for a few seconds, sometimes in sequence, then go out. Now, sart the car, some lights may come on and back off. If none stay on after a few seconds of engine running, you are probably ok.
Sep 23, 2009 | 2000 Honda Accord
Laserjet 2015n powers up for 2-3 seconds - but no lights come on - and then it powers down.
Please perform the following.
Super NVRAM initialization Turn off the printer.
  1. Press and hold the Go button.
  2. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process, the Attention , Ready , Go lights turn on. Then the Attention and Ready lights turn off, leaving only the Go light illuminated.
  3. Release the Go button. The Go , Ready and Attention lights turn on.
  4. Press and hold the Go button. All lights turn off. During the next three seconds, the Go , Ready and Attention lights turn on in that order, one per second.
  5. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
Sep 19, 2008 | HP LaserJet P2015dn Printer
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Feb 11, 2008 | RCA D61W130 61" Rear Projection Television
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
71 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
