I cant get into my routers admin page, the default password of admin/admin doesnt work, i think i changed it to something else. How do i reset the router to factory default
    Sergeant:
    Champion:
  • 218 Answers
Hi
Without knowing the exact model of router this will have to be a best guess, so if this doesnt work please can you provide the make and model detail, however as a rule the routers have a small hole on the back with a reset button ressed into them, if you hold this in for between 5 & 10 second depending on model, all the ligfhts follow a set pattern on the fron like they will all light up at once, or flash 3 times (different from a quick press), and then the router will go to factory defaults, HOWEVER please be aware this will also clear all firewall settings and may even clear your ISP logon details if you dont have a bespoke flashed unit by your supplier.
If this answer helps you , can you please provide good feed back and rate me.
Warm Regards
Andy
Posted on May 21, 2011
    Problem Solver:
  • 18 Answers
There should be a very small button hole on the back of the router.
using something small enough to fit in that hole, insert it and press the button in and hold it for 30 seconds then let it go. The lights on the front of the router may blink, go all on or a combination of both.
After you pull the small object out the router should go through a reboot cycle
It should now be reset to the default factory settings.
Hope this helps.
Change password
when i think of routers to passwords come to mind:
the administrative username and password
the wireless name (SSID) and wireless password
if you don't know the admin stuff you will need to set the router to factory defaults before you can do anything. its easy use something to push the reset button for 12 seconds. login by going to routerlogin.net or 192.168.1.1 and enter the default admin stuff "admin" and "password".
now to change the admin password (so other people can't mess with your router) go to the admin tab.
to re-setup your wireless go to the wireless tab
hopefully something i said answers your question
Aug 22, 2013 | NetGear WGR614 54Mbps Wireless Router...
This router was previously used by my sister-in-law in manila...then i brought this router in japan...when i want to install it in my computer i cant access on the site that written in the...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Computers & Internet
Im using a tenda wireless broadband..my problem is i cant get the right pre-shared key pls help
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Sep 07, 2011 | TP-LINK Tenda W311R WirelessN Router AP...
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
Sep 07, 2011 | Linksys WRT54G2 Wireless Router
Hi my belkin F7D5301 wireless router light has went from a solid green color to a solid amber color and now i cant connect to the internet unless i bypass the router i have tried resetting the router but...
It just can be ISP issue.To fix belkin router from a solid green color to a solid amber color.
Just follow these steps and let's see if they work for you
1.Restart the Modem then after 20 sec restarts the Belkin wireless router
2.After restarting you need to wait for 2 minutes
For more you need to visit https://fixingblog.com/why-belkin-router-is-blinking-orange-and-not-working/
It will be help full for you
Sep 06, 2011 | Belkin Wireless Surf Router (F7D2301)
Have new internet company cant find disc or papers need to change ip address but cant get into router settings the default admin id doesnt work
Perform a Linksys reset:
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Aug 06, 2011 | Linksys WRT150N Wireless N Router -...
After resetting my Linksys WRT16ON V3 router my name for my network was erased and the password i have set up will not connect the internet anymore, the only way I can connect a laptop is if I press the...
Plug into the router using an ethernet cable.
In the address bar of a web browser type in 192.168.1.1
The default login to the router will be
admin
password:
admin
if this doesnt work, the password is probably blank
From this page you can change any router settings to your liking
Godspeed,
Rodrick
Apr 23, 2011 | Linksys -Cisco Wireless-G VPN Broadband...
Will not let me into router. only have an option for password and nothing works. tried resetting to default and it still doesnt work
are you trying to access the router set up ?
First make sure that your computer will be connected to the router with the ethernet cable.
Now check the IP address and Default gateway on the computer. Default gateway will be the IP address of the router.
When you try to access the router it will always ask you for the password.
Try the default user name = admin and password = admin
or try user name = blank ( do not type anything), password = admin.
if that is not working then the password of the router must be changed.
try some different password that you use most often.
If that doesn't work then you will need to reset the router and reconfigure the router.
once you reset the router , you will loose all the settings on the router.
Reset the router for 30 seconds. unplug the power. plug it back in. wait for 1 minute and try to open the page again.
Click Here to know more about how to reconfigure the router
Nov 17, 2009 | D-Link GamerLounge DGL-4300 Router...
The default username and password to configure router doesnt work
Try to turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin. Also turn off any firewall you have.
Apr 01, 2009 | Linksys WRT54GL Wireless-G 54Mbps...
Connection prob
I assume you want router info - default username is admin and no password (should be on a sticker on back of router), default config web page is 192.168.0.1. If these have changed and you don't know them, it's probably best to reset the modem to factory defaults - usually by pushing reset button for about 8 secs. User manual should have this info or download it from http://www.linksys.com/ Hope this helps
Oct 03, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
