Question about Intel D102GGC2 Motherboard
I have a d102ggc2 motherboard with a dual 2.6 prossecer . i have trouble booting up goes through bios then shuts down could it be my power suplly mot stronge enough?????
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Check on the cpu/microprocessor fan is working
also check that your present smps is working properly and check the cmos battery on the motherboard
Posted on May 21, 2011
My system is turn off and turn on no loading os and bios is not working motherboard is intel d102ggc2
Have you tried pressing F2 when you powered on the PC?
Ensure that the monitor displays the signal of PC and there is no issue with video signal. If there any issue, check with RAM.
1.If no, just press it to view the bios setting. Go to the third option below.
2.If yes and no display of bios, may be your BIOS ROM chip failed. Before that take the C-mos battery out and try again. Almost try to replace it or you must go for a new motherboard.
3.If yes and getting into bios, check for the hard disk detection. If it is detected, try again for booting. If it is detected and not booting, try to format. If it is not detected, try changing it into another SATA / IDE port. Still it is not detected, replace the hard disk.
Aug 19, 2011 | Intel D102GGC2 Motherboard
My machine can not boot when any USB device is pluged in. Configaration:- Intel dual core, d102ggc2, 1.5 GB RAM
You already have the right answer dear user, your USB device cannot read by your system it maybe damaged. Try to replace another USB device. Also, maybe your startup in your CMOS/BIOS setup is set in First boot to USB device. Change it to first boot to HDD.
Apr 29, 2011 | Intel D102GGC2 Motherboard
My mather board driver is not working because bio problem
just reset you bios and see. i will tell you simple way to reset your bios
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
Nov 29, 2010 | Intel D102GGC2 Motherboard
I have a D102GGC2 motherboard with intel pentium 4 processor 524 , LGA775 Pkg 3.06GHz,.So please tell me about related drivers and chipset and how to download from intel site ?
Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
Manufacturer:
Intel
Part Number:
BOXD102GGC2
General
Product Type
Motherboard
Form Factor
Micro ATX
Width
9.8 in
Depth
8.6 in
Compatible Processors
Celeron D ,
Pentium 4 ,
Pentium D
Processor Socket
LGA775 Socket
Multi-Core Support
Dual-Core
Chipset Type
ATI Radeon Xpress 200 / AMD IXP 450
Max Bus Speed
800 MHz
Storage Controller
ATA-133,
Serial ATA-150
Power Connectors
4-pin ATX12V connector,
24-pin main power connector
Processor
Installed Qty (Max Supported)
0 ( 1 )
Memory
Supported RAM Technology
DDR2 SDRAM
RAM Installed ( Max )
0 MB / 2 GB (max)
Supported RAM Speed
PC2-3200,
PC2-4300
RAM Features
Dual channel memory architecture
Video
Graphics Controller
ATI Radeon X300 Shared video memory (UMA)
Audio
Audio Output
Sound card
Audio Codec
Realtek ALC861
Compliant Standards
High Definition Audio
Telecom / Networking
Networking
Network adapter - Realtek RTL8101L - Ethernet,
- Fast Ethernet
Features
BIOS Features
ACPI support,
SMBIOS support,
Rapid BIOS boot
Hardware Monitoring
System voltage,
CPU fan tachometer,
Chassis fan tachometer
Sleep / Wake Up
Mouse wake up,
Keyboard wake up,
Wake on USB port,
Wake on LAN (WOL),
Wake on PCI device,
Suspend to RAM (STR)
Expansion / Connectivity
Expansion Slots Total (Free)
1 Processor - LGA775 Socket,
2 Memory ( 1.8 V ) - DIMM 240-pin,
1 PCI Express x16,
1 PCI Express x1,
2 PCI
Storage Interfaces
Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
Interfaces
4 x Hi-Speed USB - 4 pin USB Type A,
1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
1 x Storage - Floppy interface - 34 pin IDC,
1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
1 x Microphone - Input - Mini-phone 3.5 mm
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
Hope this helps.
Nov 27, 2010 | Intel D102GGC2 Motherboard
No bios booting on start up
The model number you provided is incorrect.
It is most likely, D945GCNL. Intel site for your MB; http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
If you’re currently using 2 DIMMs of memory remove one DIMM. Open your manual to page 11. First remove DIMM "L". Attempt booting your system. Listen for possible bios beeps. Than shut the system down and remove the memory from " K " and insert your second memory DIMM. Again, boot system and listen for bios beeps. Intel suggest when installing memory on to the D945GCNL motherboard that it be done in a specific manner. See, 1.4 System Memory Page 16, in the TechProdSpec.pdf manual provided below; http://downloadmirror.intel.com/15115/eng/D945GCNL_TechProdSpec.pdf
The power supply currently in your system with does not provide enough wattage for your motherboard. To help find how much power you do need open the next link provided; http://www.journeysystems.com/?power_supply_calculator
It’s better to have more wattage power than you need. Even though you have an Intel manual for your board it’s suggested you download it from Intel. You'll need Adobe reader to view the manual. With Adobe you can use the zoom in feature. The next pdf link is your manual;
http://downloadmirror.intel.com/15115/eng/D945GCNL_ProductGuide02_English.pdf
I do not think there is anything wrong with you bios or your system memory. I think your system is under powered.
Happy holidays!
Mike
Dec 20, 2009 | Intel Motherboard
D845GVAD2
This can be a sign of bad power suplly,
The fact that it turns on is not a sign that is working properly.
Test with different power supply
Jun 10, 2009 | Intel D845GVSR Motherboard
Memory channel mode
Hi shinde32, you should know that dual channel memory should be bought as a pair. Your board has two DIMM slots as you mentioned. The board can handle up to 2GB max memory, as you have mentioned. What you do not seem to know is it is required to use the same amount of memory is each slot. See the bottom of page 55 in your manual. (Do you need the manual)? Download at this link;
http://download.intel.com/support/motherboards/desktop/d102ggc2/sb/d4798502_en.pdf
There is not a bios setting where you can enable or disable memory channels. The bios configures the memory automatically. Intel has a list of memory tested & passed for the D102GGC2 Mb. You can see that list at this next link.
http://www.intel.com/technology/memory/ddr/valid/DDR2_sodimm_results.htm
Bottom line, both DIMM slots should have two 512MB DIMMS or two 1GB DIMM's. (Like this memory);
http://www.bzboyz.com/ProductDetails.asp?ProdID=18112
https://www.thefind.com/computers/info-spd-dual-channel-kit-memory
This is what your search would look like,
"1GB x 2 DDR2 dual channel 533MHz SPD memory".
The Certified "SPD" is important for Intel MB's.
Good luck shinde32!
Need more help, post here.
Thank you for using fixya.
Mike
Jan 15, 2009 | Intel D102GGC2 Motherboard
Same thing
bad power suplly alot dust in it blow it out screw mobo screws tight down reseat everthing inside chesak power plugs is it well vented
Jan 09, 2008 | AOpen AK77-8X Max (91.8A710.101)...
Intel D102GGC2 Motherboard Logo
121 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
