HP pavilion dv3 shift keys not working - Computers & Internet
SOURCE: I had HP pavilion dv3-2175ee
dv3-2175ee want webcam driver
Posted on Dec 27, 2010
  • 69 Answers
SOURCE: no full screen display on
Click Fn + F7 after attaching HDMI Cable.
try this one, twice or thrice u will find a solutions.
Thanks.
Posted on Mar 22, 2011
  • 25 Answers
SOURCE: I cannot wake up my
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
Posted on May 05, 2011
gsage
  • 180 Answers
SOURCE: hi... how can i turn on the double click on
access control panel - select the mouse - select device settings - then the setting button - the rest is straight for for all the settings are displayed or hit default
Posted on Jul 10, 2011
Testimonial: "thnx"
  • 6771 Answers
SOURCE: how do i get a
On the DVD door you will notice a pin hole, use a fine screwdriver or a pin push in until you hear a click, door should pop open, now pull it all the way out exposing the mini disc.
Posted on Sep 17, 2011
Pavilion dv3 power on and off continous and screen blank
Computer Keeps Rebooting - cannot access Safe Mode
1. Boot up with Windows installation CD 2. It will give you the option to use RECOVERY CONSOLE 3. Type chkdsk to check disk - this fixes bad blocks and moves data to another area. 4. When completed, remove Windows installation CD and reboot computer
Mar 01, 2013 | HP Pavilion Dv3-1075us Notebook
Why does my HP Pavilion leak electricity?
Sounds like a power jack problem where the charger plugs in has a short or is touching other components near it.
Dec 16, 2011 | HP Pavilion dv3-2150us Notebook
How do I access the fan on an HP Pavilion DV3 Laptop? I've taken it apart with the online guide available but that failed to access the cooling fan. Laptop is overheating and it's clearly the...
Honestly, try harder. If you've taken the thing apart, you're more than half way there. You probably just need to unscrew more stuff and pry more parts out.
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
Hi... how can i turn on the double click on touchpad ... my laptop is hp pavilion dv3
Jul 04, 2011 | HP Pavilion Dv3-1075us Notebook
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
May 05, 2011 | HP Pavilion Dv3-1075us Notebook
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
I had HP pavilion dv3-2175ee loptop. i want driver for "network controller" ???
I just went and looked it up for you. I hope this link works for you. I was able t osee 7 network drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=4029989
Best of luck..
Nov 18, 2010 | Computers & Internet
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
