Question about Casio FX-115ES Scientific Calculator
How can i convert a decimal degrees on my casio fx-9860G AU PLUS to degrees,minutes,seconds
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Use the ->DMS command in the [OPTN]-[ANGL] menu. Press the OPTN key, then select ANGL.
Posted on May 21, 2011
Angles degrees plus enter
In Run>Mat or in PRGM press the OPTN key. Pan to the next page by pressing F6>. the F5:ANGL
To enter a number in DMS use the F4: [deg '"]
Example :type in 15 deg 45 minutes 10 seconds
15 [F4] 45 [F4] 10[F4] then enter. The result is displayed in Decimal Degrees as 15.7277778
Press F5 [deg '"<==]
The number is converted to DMS.
See the screen capture.
Dec 27, 2013 | Casio Algebra FX 2.0 Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How do i enter 50deg,25minutes,23seconds into a casio fx-9750 plus
In Run>Mat press the OPTN key, Then F6:> to move to the next page of options. You will see the ANGL tab as on the screen capture (above F5 key.
Press F5. You will see what follows.
Type in 50, press the F4 key, 25 then F4, 23 then F4. Press EXE. you get the result in decimal degrees as on the screen capture. To convert from DMS to D.D, or from D.D to DMS, vice-versa, press the F5 key
Jan 05, 2013 | Casio FX-9750GPlus Calculator
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
I am trying to locate the minute key on my casio fx-9750GII. I can find the degree and second key but not the minute key.
In Run(/Mat) press the OPTN key. Then press F6 to find other options.
Press F5:ANGL Here is what you see.
To enter an angle in decimal degrees, type in a decimal value then
press the F1:key to insert the degree symbol.
To enter an angle value in DMS, press the F4 key after each part.
See the next screen capture.
The menu option key above the F5 key, converts from DMS to DD
Sep 08, 2011 | Casio FX-9750GPlus Calculator
Can I convert Decimal Degrees to Degrees, Minutes, Seconds on my casio fx-991 ES?
Yes. Pressing the DMS key (two keys above the 8 key) when a result is displayed toggles the result between decimal degrees and degrees-minutes-seconds.
For example, to convert 3.5 degrees, press 3 . 5 = and you'll see 3.5. Now press DMS and you'll see 3 degrees 30 minutes 0 seconds.
Jul 31, 2011 | Casio FX-115ES Scientific Calculator
How do i convert a degrees/minutes/second problem using the Casio Fx-115ES calculator? Can you provide an example? Thanks ZH
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
Sep 25, 2010 | Casio FX-115ES Scientific Calculator
Can I convert Degrees, Minutes, Seconds to Decimal Degrees on my casio fx-115 ES?
Press the SD key (just above DEL). You may have to press it twice if the first press produces a fraction.
Sep 19, 2010 | Casio FX-115ES Scientific Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
313 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
