Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
How could I remove the impeller to rotate the discharge.
    President:
  • Waterway Master
  • 1,378 Answers
You do not to to remove anything on the pump end to rotate it. Loosen the 4 motor thru-bolts at the end opposite the pump; they pass all the way thru the motor into the pump bracket. Once those are backed out you can spin the pump discharge into the position you need and reinstall the thru-bolts...done!
John
Posted on May 21, 2011
How do you know if the enpeller is on the wrong way, ya I know no water coming through, but there is air and the motor is in the water.
I presume you're referring to a submersible pump. the impellers are either centrifugal or screw type. Check the direction of rotation by turning the pump on without the impeller installed. Then install the impeller so that the blades can draw water into the pump body and expel it at the discharge discharge outlet.
Oct 06, 2013 | 172550003P Spare Impeller And Shaft
How to remove impeller on Pentair ultra-flow pump
Remember to remove the impeller locking screw (left hand thread) before attempting to unscrew impeller.
May 05, 2013 | Pool & Spa
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Rattles when drying
I need more details but typically a dryer will make a rhythmic rattling noise when loose change and other small metallic objects as well as buttons become trapped in the tumbler impellers (those wing shaped things in dryers).
Loosen and remove the top of your dryer.
Rotate your drum, taking care not to rotate it the wrong way. The right direction of rotation will produce friction to the belt, the wrong direction will cause slack on the belt on one side or the other of the drum.
Rotate the drum until the back side of the impeller is directly on top with the outer screws facing you at the top of the dryer. Remove the screws and pull out the impeller and you will find your noise makers. Do this with the remaining impellers and reinstall.
Mar 05, 2010 | Dryers
Wash impeller wont rotate on fisher paykel model 603
I suppose you have a double drawer dishwasher and this problem is with one of the drawers.
One cause of the impeller not rotating would be that there is some loose cutlerry lodged between the impeller arm and the base rack. This is easy just remove it.
HOwever, the other option is that the impeller itself is stuck. Try opening the filter base plate and removing the impeller rotor to check if no debris is lying around (usually food scraps).
The instructions to open the filter plate and exposing the impeller is in the user guide. If cleaning does not help then check nothing is stuck in the filter sump and the narrow passage connecting filter sump and the rotor cavity which is preventing the rotor from rotating.
The worst case scenario is the impeller rotor is faulty. You can buy this and replace yourself , ie, if you worked out how to remove it.
Good luck
Nov 17, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
How do i remove impellor
The impeller in my 4 HP, 2-speed Waterway Executive High Performance 56 pool & spa pump has a brass coupling embedded in the back side. This coupling can be unscrewed from the motor shaft by keeping the shaft from rotating while turning the impeller in the reverse direction. Then the seal can be tapped out.
Oct 08, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Wont drain have cleaned out pump for coins anything else it could be
You cleaned out the pump, but did you check it out? Take a flashlight and look into the suction port on the pump. Check the impeller for broken or missing blades and see that the impeller rotates freely. If there are broken/missing blades or if the impeller will not rotate freely the pump is defective.
Aug 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch dishwasher wont drain. At end of cycle is full of cloudy water.
It is possible if you have broken a glass recently that the piece of glass has made its way to the drain pump impeller. You need to remove bottom basket. Remove the filter strainer clamp by rotating CCW. There may be another round filter under the strainer (depending on model). Then with a torque screwdriver remove one screw which holds the plastic pump cover on. Remove the pump cover and pay close attention to the pump impeller. Does it rotate by finger movement? If not it could be jamed with a piece of broken glass. You must remove any obstruction to allow the impeller to turn. I usually force a paper towel piece (half piece while rotating the impeller by finger to allow the paper towel to bring up any obstruction below the impeller) Reassemble the cover and filters carefully and make sure the final strainer clamp aligns correctly with its marks. This insures nothing will make its way to the impeller in future.
Regards Sam
Jun 15, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
438 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
