Question about Mitsubishi VS-60607 TV
Rolling screen? Mitsubishi tv model vs 60705. It rolls right to left, but when you turn the pip on it doesn't roll on the pup screens. What is the problem? What part do I need to fix it? I already have the back off if the tv and the fuse board pulled out.
  • 373 Answers
I want you to know I have been where you are on this same TV and what I found is there are three ICs all in close proximity on the SIGNAL BOARD that I recommend strong you try REPLACING all caps on the ICs as follows:
IC2P02--12 volts input and 9 volts output
change C1P01 on input 47 mfd/35 volts
change C2P03 on output 100mfd/16 volts
IC2P01--11.9 volts on input and 9 volts output
change C2P04 on input 47 mfd/50 volts
change C2P05 on output 100 mfd/16 volts
IC2P03--4 volts on input pin 5 and 3.2 volts on output 1 and 3.7 volts input on pin 2 and output pin 4 is 3.2 volts.
change C2P07 47 mfd/35 volts
change C2P09 100 mfd/16 volts
I know this is a bit technical but it is what is wrong with your set. Caps have polarity (positive and negative connections) They all must be unsoldered and new ones soldered back
The Signal Board usually has the tuner on it where the coax connects. The board needs to be removed by unplugging it to change the caps.
Posted on May 21, 2011
  • dominicdiese Feb 22, 2012
    Other than the caps, could it be the (FBT) flyback transformer? Just wondering cause I too now have this same problem...
  • TV Doctor
    TV Doctor Feb 22, 2012
    It is not the Flyback...this part has to do with high voltage output to light the screen..the problem is in the horizontal sync and those capacitors I mentioned deal with this. It is a common problem with this Mitsubishi.
Picture is rolling sometime double images after awhile it stops and then starts rolling again
Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 25, 2010 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi Vs-60705 Bigscreen turn on vertical roll warms up stops rolling and begins jumping up and down also picture is not clear
Check C2P05[ location on convergence board]. This is a 16volt 100Mf cap that is bad. And check out C2V29 [cap value is 16volt 22 Mf.] And still while you're at it, resolder the pins on the convergence ICs.Should fix your TV!
Nov 29, 2009 | Televison & Video
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi vs-7071 rear projection tv
hey i have had the same prob on my other tv .it was about 300 to get it fixed.if you havent allready fixed it and if your not to fare away,id like to buy the screen
Jul 29, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Mitsubishi tv model VS6061 rear projection with rolling picture.
I know this is an old thread, but I would like to post this information in the hope that someone will find it useful.
I just finished fixing this problem on my 1994 VS-6061... the problem is the PIP (Picture In Picture) board located on the Power Signal board. The PIP board contains the numbers 530B552. I bypassed the PIP board by following the directions I found at the following link:
http://forum.doityourself.com/entertainment-center-tvs-stereos-vcrs-dvds/130383-mitsubishi-cs-35301-rolling-picture-problem.html
"Plug in a 4.7ufd @ 35v filter cap (+)at pin 5,(-)at pin 11. Plug in a .01ufd(any voltage) between pin 7 and 9. Just plug the caps into the socket, where the PIP board was mounted (they don't need to be soldered). Just don't let the leads from the two capacitors touch, as they cross each other. The 0.01 cap is non-polarity, so either way it plugged is fine. Basically you will bypass y-signal through 4.7u, in pin 5, out pin 11, and bypass c-signal in pin 7, out pin 9 of the PIP socket.”
The bypass requires 2 capacitors: One 4.7ufd @ 35v and one Non-Polar 0.01ufd @ any voltage.
Remove the PIP board, then plug the two capacitors into the socket where the PIP board was mounted: plug the 4.7ufd capacitor with (+)at pin 5,(-)at pin 11 and plug in the non-polar .01ufd capacitor between pins 7 and pin 9.
If there is a ground wire (possibly brown) soldered to one of the tin cases on the PIP board, then you should connect this ground wire to the PIP socket either at pin 2, 4, 6, 8 or 10 which are grounds of the socket.
This PIP board was used in many Mitsubishi televisions and they were plagued with problems...This is why many of these older Mitsubishi televisions had similar problems…
Good luck
Jul 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Rear project TV problem
yes it can be fixed depending on your model number if its the VS50605 they have a kit to repair the PIP module which controls vertical sync (Rolling) or you can bypass the module to correct it but you would lose the PIP function. Let me know if you need more info.
Apr 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Continuous rolling screen.
check out ctechnicians.com and find the error code
Dec 24, 2007 | Mitsubishi VS-60607 TV
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Mitsubishi VS-60607 TV Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
