Question about HIS RADEON HD 4670, (1 GB) AGP Video Card
I bought a second hand HIS ATI RADEON 4670 1gig agp, we test it first and works fine also in my pc, then after 1 week used the video card shows no response to my monitor totally blank screen so i had to check its fan and see if it's still running and yes its still running.. I turn off the pc and remove the card and cleaned it up also i checked the cables or connection if its still intact then i tried it again still got no response from the vcard.. In order to check if its really the video card problem i tried to used again my old video card the Galaxy Fx5500 256 video card and it works fine last thing also i tried the HIS video card to other pc and same thing shows no response.. Please help me pls pls pls...... what will i do?? my computer specs: intel 3.2ghz 3gig memory mboard: p4u800-x 120 gig hd 500watts psu sonic gear (generic)
  • 343 Answers
The card could be failing. Try checking that the fans are turning on the HIS when computer is on. Also make sure the heatsink under the fan is fully touching. The card may think it is overheating so check all the connections under the cover on the HIS card
Thanks for using FixYa
Posted on May 21, 2011
Free download ATI RADEON X1650PRO 512MB AGP GRAPHICS VIDEO CARD
Click here to get the latest available drivers for your ATI Radeon X1650Pro.
On the right hand side of the page their is a quick driver download section. With a heading Download drivers.
Select the following:
First field: Desktop Graphics.
Second Field: Radeon X Series.
Third Field: Radeon X1xxx Series.
Fourth Field: Select the operating system that are running this graphics card on.
Now click View results.
Then it may say that you should use the ATI Catalyst 9.3 Driver, however the 10.2 version is available for download. I would try it first just in case it works.
If not you will have to download and install the Catalyst 9.3 Driver.
Take care!
damnor01
Sep 18, 2011 | ATI RADEON X1650 Graphic Card
Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Jun 15, 2010 | ATI RADEON 9550 Graphic Card
Suitable agp for playing gta 4
The AGP slot on this system is 4X
The two cards that were tested on this from Dell are
ATI 64MB Radeon VE 7500 ATI 32MB Radeon
The maximum card you can connect to the system any PCI video card not more than 128 MB. As the motherboard and the power supply would not support it
Thanks
Proton
May 25, 2010 | Dell OptiPlex GX260 PC Desktop
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
Video card
The MSI KT4V motherboard is an AGP board supporting 4x/8x AGP. You cannot use a newer PCI-Express Video Card, however an Nvidia GeForce FX 5500 either PCI or AGP will run just fine in it. The NVidia FX 5500 doesn't come in PCI-E. Additionally The ATI Radeon 9550 doesn't come PCI-E so you should be safe with AGP versions of either. I should note however, that you'll get better performance out of the ATI Radeon 9550 as opposed to the NVidia FX 5500.
I hope this answers your question,
Analog Anomaly
Dec 18, 2008 | MSI KT4V (MS-6712) Motherboard
Radeon 9600 XT AGP - wn't activate second monitor as TV output.
hi
check if you have the latest software or not if not download from http://ati.amd.com/support/driver.html this will give you a more simple and easier way change the double monitor settings
Nov 12, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site: http://www.colordrives.com/sapphire-ati-radeon-9550-256mb-ddr-agp-4x-8x-video-card---retail-box.html
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Oct 30, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
HIS RADEON HD 4670, (1 GB) AGP Video Card Logo
183 people viewed this question
Top HIS Computers & Internet Experts
Ali Asghar Khambati
Ali Asghar Khambati
deton8 von Splosion
Don Eagan
Are you a HIS Computer and Internet Expert? Answer questions, earn points and help others
