Hp pjhotosmart c7200, error code 0xc18a0001 - Office Equipment & Supplies
mace1mace
  • 1138 Answers
SOURCE: 0xc18a0001
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Posted on Jun 02, 2010
SOURCE: my hp photosmart D7145 printer
my photsmart 6180 error 0xc18a0001
Posted on Sep 16, 2008
  • 5 Answers
SOURCE: I have a hp 3310 photosmart with a error
Try these steps!
Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example)
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Hope it was useful...........cheers
Posted on May 14, 2009
SOURCE: have hp photosmart c7200 all-in-one
Go to fax setting and change resolution to standard. Worked for me.
Posted on Jun 02, 2009
pineworks
  • 4041 Answers
SOURCE: error code 0xc18a0001 HP Photosmart 3210 All in
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
Model 4225 shows error code only
'Ink System Failure,' or a '0x...' - HP Customer Support
support.hp.com/us-en/document/c03081973
Example: "Laserjet P1102w driver" or "HP Pavilion 17-f002na will not turn on" ... For example, 'Error 0xc18a0001' or 'B8000094' might display on the printer ... The error code or message is not 'Problem with Printhead,' 'Printer Failure,' or 'Ink ...
[PDF]hp officejet 4200 series all-in-one user guide
www.hp.com/ctg/Manual/c00095626.pdf
Hewlett?Packarduse the attached handset (hp officejet 4250 series only) . . . . . . . . . . . .50 answer incoming calls ..... Help button that appears on some error messages and in the. Troubleshooting .... a call waiting (handset model only). 9. Photo Fit to Page: ...
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Dec 18, 2015 | HP Office Equipment & Supplies
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
I have a HP Photosmart All-in-One series C7200. I keep getting an error message saying "Image on Fax Teport is set to Off". Error 388. The proble occurs when we try & send long distance. What should I...
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
to check the error codes and there solution
click on the following link Hope you its satisfactory
ERROR CODES C7200 Series
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&cc=us&lc=en&dlc=en&product=3382185#Error386
Jan 03, 2010 | HP Office Equipment & Supplies
301 people viewed this question
k24674
