Question about Foxconn 661MX Motherboard
Need help bought a brand new 661mxplus motherboard,getting no power to fans and the computer won't turn on at all.Don't see no light on the motherboard
  • 781 Answers
Do you have all the power supply cords fitted into M/board
M/boards nowadays have 1 large white plug and sometimes 1 smaller 4 pin one or an 8 pin one
Does your power supply have them if not you will have to upgrade tou power suplpy
Posted on Aug 15, 2008
My Fujitsu Lifebook AH531 won't start up all all, as if the battery is dead. I've bought a new charger and the problem remains. Can anyone help please.
you need to find out if you are getting voltage to motherboard may be a bad jack if you do not have the tools bring to a repair shop
Jan 19, 2013 | Fujitsu LifeBook AH531
Help new power supply will not power up.
if you had a surge, it could have damaged more than just the power supply. When you plug in the unit, does the power indicator light up??? your main board could also have damage. The main board sends a signal to wake up the power supply thus turning on the TV. If you have to replace the main board as well, it probably won' t be economical to repair the set.
May 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
My Dell insperion won't power up at all. I bought a new battery and tested the charger and am getting the 19.5V that I am supposed to get. I don't know how to test the battery to see if it is...
If working should turn on with adapter plugged in, maybe the internal jack is broken, move adapter plug around slightly and see if it moves at all, should not. Does any lights com on or do you hear the fan ?
Nov 01, 2017 | Dell Inspiron 1150 Notebook
My PC is not starting what is problem.
first make sure your ac cable is working well, then try to check the power supply of your computer if the fan rotates every time you hit the power button of your cpu, if not then change your power supply. if it fan rotates and stops, try to used another power supply if fan rotates and still won't display open up your cpu try to check if the fan over the processor will rotate and still don't recieve display. try to remove the video card and memory and clean it and re insert it. if still don't work. you got your motherboard defective.
Jul 10, 2011 | Intel SRMK2 Motherboard
I got a gigabyte motherboard, when i hook it up the only thing that comes on is the fan itself, the hard drive dont light up and neither does the dvd rom....now i bought two brand new processors for it, i...
Sounds like the first thing you need to check is if you are getting all the voltages out of your power supply.
Here is a link to the pinouts of the connectors. if you have a faulty PS replacing the CPU or motherboard will not help.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm
Is there a green LED on your motherboard at all?
You said the fan comes on. Which fan? You should have a CPU fan, a case fan, and a power supply fan.
Sep 29, 2009 | Computers & Internet
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
Computer turns on then shuts off.
Hi there.
Have you tried clearing CMOS? look on the motherboard for the battery, the jumper should be near that and with most motherboards should be marked with "CLR_CMOS" like this >>>>>
If you cannot find the jumper then chances are the board does not have one so to clear the cmos you have to take the motherboard battery out for an hour or so making sure you remove the power cord from the back of the machine, also take out and reseat the memory
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 21, 2009 | Foxconn 661FX7MF-S Motherboard
Not posting
Maybe a silly question to ask; but did you connect the processor power lead, as unlike some processors this needs a seperate supply.
Dec 18, 2006 | Mach Speed MK8-939A (VIPERMK8939A)...
Foxconn 661MX Motherboard Logo
82 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
