Question about Andis 22340 Agc 2 speed Professional Animal Clipper
How to replace armature assembly - Andis 22340 Agc 2 speed Professional Animal Clipper
  • plazajc May 21, 2011
    I appreciate the advice. Thank You. It was very helpful.
    Juan
  • 776 Answers
The exploded view of the clipper can be found at:
http://www.andis.com/USA/PDF/ServiceParts/12696Rev-L.pdf
Once you open the case (4 screws) you will need to remove the two screws near the cutter head (labeled #17 in drawing) and two on the circuit board (oposite end of board that power cord is attached to (labled #5 in the drawing)). Remove the circuit board carefully (there are wires with carbon brushes attached). Then lift out part labelled #11 (rear motor frame). After that, the armature should just lift up.
It may be possible to remove armature without removing the "#17" screws. Just lift the rear motor frame out then slide the armature back and lift out.
If you have any trouble at all, you can call the Andis customer support line. The team is really good. I have actually been to their factory and the design team is great. Amazing they can keep making a product like that in the US.
good luck.
-Mark
Posted on May 21, 2011
I overheated my Makita 9557PB angle grinder. I replaced the brushes. Bearings seem ok: the motor assembly turns freely, smoothly, and quietly. The running motor is slow, with a loud "grinding" sound.
Measure the value difference in Ohm between the carbon brushes on the armature there are some collectors in the commutator give an other ohm value if compared to other collectors in the comutator of the armature . if measure turn the blad very slow so the collectros can be positioned to measure the ohm difference. range to measure 0-200ohm on ohmmeter.
If only one brush made trouble ( much more sparking ) then the electric field is not in ohm value balance, control always if there are slide contacts used they are solid. on the field. Measure the difference. between the 2 field coils of the electric field . if its also different replace allways the field and the armature if thats also have problems (BUT DON,T FORGET to order a new drive gear for the armature and new brushes. !!!
Aug 28, 2016 | Makita 4-1 2 in Grinder 9557PB
When i pull the trigger the motor runs but does not reciprocat like its not ingauging or something
http://www.ereplacementparts.com/output-shaft-assembly-p-160489.html?osCsid=b8lnbd8lbuoj9ufqn81simcuo3 OR
http://www.ereplacementparts.com/gear-assembly-p-160488.html
AND if it has it also a crushed teeth problem the armature MUST even be replaced
http://www.ereplacementparts.com/armature-wbearings-p-160485.html
Beware there are several parts be discontinued and look on all parts, the year of building how many workinghours its got on it before decide to repair .
an broken saw shuttle or pin
Apr 17, 2016 | Ridgid R3001
How do I remove the gear from the gear housing assembly?
first grinding wheel > flange> safety cap > 4 screws >remove axis with drive shaft crown wheel > then 4 screws remove front with the armature if you must replace cone wheel and crown wheel. remove first the carbon brushes before take the armature out.
Dec 29, 2015 | Dewalt 4 1/2" Small Angle Grinder D28402
Armature removal
Armature should just pull out. Try holding the armature and tapping the main housing with a soft mallet.
Drawing http://www.milwaukeetool.com/PartsAndService/DownloadManuals/PartsWiring.aspx?ProductId=6180
May 06, 2012 | Saws
How do I replace the fan assembly cannot hold armature assembly to get inner bearing out without damaging armature assembly
If you are replacing the fan assembly because the internal thread that holds the rubber/velcro pad has stripped, there might be an alternative.
I had the same problem with my PEX 12AE, which I believe is a similar sander. I found that the hole is threaded a good bit deeper than the screw, so I got a longer screw and so far it's holding ok. If/when that fails, I might try repairing the thread with an insert.
Curious to know how you managed with your sander.
Feb 09, 2012 | Bosch 3107DVS Electric Sanders & Polishers
Reciprocating saw armature removal
usually there is a screw in the diaphragm to hold that assembly tight. You need to remove the brushes first and you might need to GENTLY pry the diaphragm from the motor housing. Then using a soft blow hammer tap the armature out of the plate. I would recommend replacing the bearings and brushes when doing the armature. Let me know if you need more assistance.
Dec 29, 2011 | Saws
Blade assembly does not tighten
check out toolpartsdirect.com for parts diagram.
Jun 18, 2008 | Black & Decker 19" Electric Lawnhog...
problem could be the armature ring/ drop. it's for the bearing stopper. if the ring slip off from the grove, all you to do is to put it back to the grove & make sure that the grove are in good shape..its common problem for older armature type.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Andis 22340 Agc 2 speed Professional Animal Clipper Logo
198 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
