Question about Cameras
IT IS NOW A DEAD SET. IT WAS BEING USED WITH A WRONG POWER SUPPLY WHICH IS 12 V DC.
    Sergeant:
    Champion:
  • 214 Answers
Hi, What model of camera is that? you might check out the power control circuitry(DC/DC convertor) Thanks and good luck?
Posted on May 21, 2011
Can I charge unit with a male to male on the 12 volt port asking about unit Stanley JS900CS Not Jump-N-Carry
Tool review: Jump-N-Carry jump starter -- Portable model ...
www.autoserviceprofessional.com/.../tool-review-jump-n-carry-jump-sta...
Jun 6, 2014 - The Jump-N-Carry's convenient charge indicator reveals the unit's stored voltage. ... By plugging the male/male adapter cable into the Jump-N-Carry ... This 12-volt DC port also can be used to power 12V accessories (up to 12 ...
Using The Unit As A 12 Volt Dc Portable Power Supply ...
Jan 01, 2016 | Cars & Trucks
I have a desktop PC that when I turn it on it will power up and then after 6 seconds turn back off.
The first solution is right on the money, It's the video card, or many of us today forget to plug the damm thing in and the computer doesn't read and we think that there is a serious problem. If none of this helps then try troubleshooting through this PC repair guide. Hope this helps.
Dec 29, 2011 | E-Machines eMachines Desktop PC
How to install 12 volt led light bulbs in the 220v Power Supply
Buy a lamp holder and 220V AC to 12V DC power supply, power supply should exactly be connected with the positive and negative holder, plug in the power, 12 volt led light bulbs can be used.
Dec 01, 2011 | Cars & Trucks
Stairmaster 4400 PT dead after power surge
Check the voltage output of the power supply. It should be over 12 Volts DC. The following link will take you to a video explanation of how to use the required meter on your power supply.
Video about Multimeter Testing
Sep 11, 2010 | Stairmaster 4400 PT Stair Stepper
Put wrong power adapter into a Yamaha DTXPRESS IV
You should immediately quarantine what you plugged in and compare it to the correct one.
IF you put too low aq voltage of the CORRECT polarity nothing should have happened.
If you put backwards polarity of any voltage the regulator is probably fried internally and possibly an input bypass cap. Also if you put an AC adapter and it wants a DC the same destruction could happen.
if you put too high a voltage, possibly the power input cap may be bad.
It appears that the correct supply is the PA3C which is a 12 volt, 700ma with positive on the center pin.
Mar 29, 2010 | Yamaha Music
I have Yamaha psr 260 and I am connect on 24V, and now speakers dont work. What am I doing?
I believe that is the wrong VOLTAGE !!!
The PSR takes a 12 volt, 1 amp or more DC power supply with positive on the pin.
If you have connected 24 volts either AC or DC of either polarity you have likely caused internal damage. Try a 12 volt DC supply and if it doesn't work, it needs to go to a repair facility.
ALWAYS check the voltage and the polarity on ANY of the devices using the power adapters BEFORE connecting the adapter..
Feb 18, 2010 | Yamaha Music
No power to my router
Check the wall outlet for power, using a lamp or such. If you can get a multi-meter, set the meter to Volts-DC between 12 and 20. Plug the power supply into the wall outlet and test the other end for voltage. The power supply should tell you its output so the reading should be more than a couple of volts. If it is less or ZERO the power supply is dead. If it has power, then open the router and check for a fuse. If the fuse is dead, replace. If there is no fuse or the fuse is OK then the router may be dead. Best of luck.
May 29, 2009 | Linksys Wireless-G Broadband Router
Cameras Logo
16 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
