Question about Toshiba Satellite L500 Series Notebook
Replacing monitor - Toshiba Satellite L500 Series Notebook
  • Toshiba Master
  • 4,338 Answers
Here is a tutorial on how to change the LCD :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L500-L505/remove-lcd-screen-inverter-1.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 21, 2011
Replacing leaky cuff
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
press the helpful button and follow me on fixya for more tips
Blood Pressure Monitors Parts and Accessories
Blood Pressure Monitor Replacement CuffWalgreens
http://www.walmart.com/c/ep/blood-pressure-cuffs
OMRON Healthcare Blood Pressure Monitoring
Feb 03, 2016 | Health & Beauty
Monitor screen momentarily flashes and blacks out
Most likely the power supply. Bad capacitors, if you think you can solder in new ones, good. If not; buy a new monitor
Nov 26, 2017 | ASUS Ve205n 20" Widescreen Lcd Monitor
Why the monitor light switch off
Is this just the light or the monitor shuts down as well. This could be the circuit board for the buttons they are relatively easy to replace and purchase depending on the monitor. If it is an LCD monitor more than likely this is the issue if it is a CRT and the monitor stays on either get a new monitor do not waste money CRT's are easy to get these days. If it is a LCD since it was not specified replace the board for the button control only. If this does not solve the issue if the LCD monitor shuts down after replacing the button card. Then you can purchase a repair kit for your LCD monitor you will have to have knowledge of soldering to replace bloated capacitors you may find.
I have repaired many a garaged LCD monitor for a $17.00 dollar repair kit. So either way what is affordable to you. New monitor or board "Button" replacement or expensive shop repair to fix capacitors....John.
Apr 12, 2012 | Computers & Internet
There are some kind of coloured dots and patches all over the monitor and the same thing appears even after switching it off and switching it on again.
Seems that you Monitor is having issues with the pixels.
You mentioned that it also is present when turning ON and turning the Monitor OFF right, if that is the case then you monitors screen needs to be replaced.
A pixelated monitor can only be fixed if replaced.
When you say Monitor do you mean a CRT Monitor or an LCD Monitor? for a CRT Monitor it is just going to be like a TV the picture tube can be repaired or a part can be replaced but for an LCD Monitor that will be replacing the LCD Panel.
Aug 08, 2011 | Computers & Internet
I was given a 17" flat screen monitor and the cable to connect it to the computer plus the power cord are missing, can I replace them?
yes. you can replace them with replacement cable for monitors. Just go to your nearest computer store and ask for replacement cables provided with the Brand Name of the monitor.
Aug 31, 2010 | Sylvania CL772B 17" Flat Panel LCD Monitor
Nokia 800+ monitor - screen is blinking approx.
I think the problem with your monitor is that, the picture board on the monitor is malfunctioning that is why it keeps going blank after a minute.
What you need to do is to replace the picture board on your LCD monitor, replacing the picture board will solve the problem, because the picture board on the monitor at the moment is bad and will need to be replace.
Replace the picture board and you will see that the problem will not repeat itself again.
Take care.
Jul 17, 2010 | Nokia 800 PRO+ Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    LCD flat panel monitor blinks logo over and over
    Sounds like the LCD monitor is not getting a proper input signal. Check your cables between the computer and monitor. Replace them if need. Also check the pins and make sure that none are bent or disfigured.
    Try a replacment monitor from a family member or friend. If their monitor works ok.....then your due for a replacment. The are very little user servicable parts inside.
    Jan 23, 2009 | IBM ThinkVision L170 17" LCD Monitor
    Cracked face panel on monitor
    Yes, the LCD screen "face panel" can be replaced. However, note that this part is the most expensive part of the monitor. If your monitor is more than a year or two old, it may be difficult to find a replacement and it may be more cost effective to simply replace the whole monitor.
    Oct 11, 2008 | HP vs19 (Silver) 19" LCD Monitor
    Toshiba Satellite L500 Series Notebook Logo
    91 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
