Question about Nady Systems Nady Encore II GT Wireless Instrument System, Channel D
Broke the antenna off my Encore II . Where can I get parts?
  • 4,234 Answers
Contact Nady directly at the number below. They will help with the part number and cost etc.
Dan
Contact: Customer Service Department at (510) 652-2411.
Posted on May 21, 2011
What is causing my 1967 Hagstrom II guitar pickups to have an RF interference hum and how can I eliminate it?
I would say your first impression was correct, even though the additional image you submitted is impossible to view clearly. Single coil pickups are particularly vulnerable to 60 Hz EMI (50 Hz in some parts of the world) from AC power lines, and depending on the values and lengths of connecting wires can be surprisingly good antennas for broadcast radio stations or CB transmissions 8^0. This is managed with proper shielding around the electronics cavity in the guitar body, and sometimes, particularly in North America, by connecting the the ground side of the audio circuit to the bridge, which then connects the ground to the strings and then the human body through the hands, allowing it to act as an impedance sink. Best practice has all wires carrying audio signal surrounded by a mesh shield connected to a common point audio ground.
Aug 23, 2017 | Hagstrom Viking II UltraLux Electric...
I have a Williams Encore Digital piano. When I power up there is no sound. Upon power up there are 8 small rectangle on the LCD screen. 7 red light are lit. They are the 4 lights above the "user...
Holding the page up and down buttons while powering on supposedly resets it. I have no sound except demos, but no lights showing like yours, and williams tech support said to reset that way but it didn't seem to do anything. Good luck hope this helps!
Jun 27, 2011 | Williams Encore Digital Piano
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
I broke the passive biamp switch off the back of my 1800 x subwoofer. i have been using it like that but now its not working. can i buy just the back panel with the switch on it or do i have to get another...
You can get replacement switches. The internals of the switch probably broke and no longer connect causing the speaker to not work. FullCompass.com is the Behringer parts distributor but they may direct you to first call Behringer to get a part number for the item.
Feb 14, 2011 | Behringer EUROLIVE Professional B1800X Pro...
The Williams Sytmphonic keyboard was toppled and disconnected feom pedelshow to reconnect expressikon pedels to piano keyboard
Here is a link:http://www.williamspianos.com/products/encore.cfm If you don't have one, download the manual. If it still doesn't play correctly with the pedal connected according to the manual you will have to contact them to see about servicing. The information is also at that link.
Aug 18, 2010 | Williams Encore Digital Piano
The input for the ac adapter is loose and cuts outt all the time.
Connector is probably damaged. If you can open the unit you can get replacement connector from DigiKey.com and Mouser.com. You need to compare dimensions of the barrel AND the pin to insure you get the correct part. Also the pins that go through the board. One could go through Williams, but they may not have a parts dept.
Aug 11, 2010 | Williams Encore Digital Piano
One of the tips broke off and cover does not stay in
Well, other than replacing the cover about the only thing you can do is use a bit of gaffer's tape to hold it... Gaffer's tape is like duct tape but does not leave a residue.
Getting parts and doing the replacement would be a real hassle for sure.
Jan 27, 2010 | Zoom H4 Handy Recorder
Nady Systems Nady Encore II GT Wireless Instrument System, Channel D Logo
63 people viewed this question
Top Nady Systems Music Experts
Michial Gueffroy
Are you a Nady Systems Music Expert? Answer questions, earn points and help others
