Question about Rheem M206A 206K BTU Pool and Spa Propane Gas Heater
The display says PRS and the heater does not start
    President:
  • Rheem Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
That unit will not fire until you resolve the pressure switch issue which is what PRS indicates; either the flow is reduced too low meaning the pump/filter system needs to be thoroughly cleaned or the switch or control board has failed and need to be repaired.
Start with a cleaning of all baskets and filter to see if the light clears and the heater works; if not look at replacing the pressure switch. It is not uncommon for the switches to fail but check it with a meter set to ohms if you can. Power off the heater first and pull one of the wire leads off. Put the probes on the terminals with the pump running and see if you have a circuit. If not, replace it. If the switch tests fine the problem is in the control board and it will need to be replaced.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on May 21, 2011
Could I get a wiring diagram?
if on control panel its calling for heat sounds like bad heating element if not calling for heat bad temp sensor at about 75 degrees it should ohm out about 78 ohms
Aug 27, 2014 | Optimus Flow Thru Heater, 2 Psi Prs, for...
Sony PRST2 BC has frozen.
This screen is an electronic paper screen, meaning that when it displays an image it will stay that way until it receives electric signals that change it.
Basically, even if the device has no power it will display the last image it displayed.
Are you sure the device is certainly charged? Trying to turn it off and on whilst it's plugged in and charging will be sure of this.
Dec 22, 2012 | Sony PRS-T1 6" Digital E-Ink Pearl eReader...
Screen has prs clean filter screen and service flashing
pressure switch is open. clean out pump basket and backwash the filter.... if you have proper water flow, jump the pressure switch....if heater fires up replace the pressure switch
Jun 11, 2011 | Raypak RP2100 DIGITAL POOL HEATER R206...
Upon start heater comes on for about 5 seconds and shuts down. Then starts again and stops again, and so on. "PRS" appears
PRS means the pressure switch is opening and shutting off the heater as you describe. Either your filter and/or inlet baskets need a good cleaning or the pressure switch in the heater is failing. Try a thorough cleaning first and then replace the pressure switch if necessary.
John
Oct 25, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater " PRS " diagnostic reading What does it mean and how do i correct it
This is low pressure. Start by checking your baskets for clean then be sure to clean the filter. Then make sure the by-pass valve is closed and lastly if your pump basket is cracked or broken check to be sure nothing is clogging your impeller.
Sep 19, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 pool heater won't heat, PRS and HL2 error codes.
Well, I replaced the pressure switch with no joy. I tried all 5 levels of pressure 1-5 and every wiring combination. Finally, I returned the new $70 pressure switch and took the 2 wires and tied them together (jumped them). Here's the only downside...If you run your pump in backwash, recirc, waste, or any mode that would cause water to bypass the heater it MUST BE OFF. Otherwise, let it ride. It's working great and I hope to go into October weather permitting.
May 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a Raypac 2100 digital pool heater and it's reading PRS. Is there someone out there that can tell me where this pressure switch is? According to the guide, PRS means "pressure switch open". If I...
On the side of the heater where the pipes are connected; under the top cover. It is a round disk threaded into the header. It is likely that your filter needs a good cleaning if your heater has always worked reliably in the past. If you have a cartridge filter, it may be time for a new element if you can no longer get it clean enough to get the heater to work.
Sep 26, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Heater is off and code says prs
Assuming you have water flow, the pressure switch is bad. It is not sensing flow.
Dec 28, 2008 | Jandy Laars Lt 400,000 Btu Heater
Rheem M206A 206K BTU Pool and Spa Propane Gas Heater Logo
495 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Scott Corey-reid
David Spradling
David Spradling
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
