Question about HP Photosmart C6180 All-In-One InkJet Printer
Paper has unjammed and i need to unjam it how can i do it?
    Guru:
  • 731 Answers
Posted on May 21, 2011
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
HOW DO I UNJAM SB 99C SHEDDER
Try spraying some WD40 into the cutting blades then turn it on to forward it may unjam itself.
Aug 25, 2014 | Fellowes SB-99Ci Shredder
How to unjam shredder spl-mc1809
See this... http://www.wikihow.com/Unjam-a-Paper-Shredder
Jul 08, 2014 | Office Equipment & Supplies
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
I was trying to print and paper got jam inside the machine and I can not figure out how to unjam it. I do not have a book on the printer.
Hi
If you can unjam it I think it may got be opened to unjam it then if you not able to do this then best take it to the shop, if you do try to open it yourself be careful because there are some wires you may have take apart and where if you want the manual I have put it on my website for you to down load but I can see much in it that could help you to unjam your printer. Click on the link to download. It's in PDF
http://www.4all2sell.com/pdf/Kodak-ESP-3.pdf
All the Best: Pineworks
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
Unjam a MCFC printer
back cover is just on the back of your printer.
Apr 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
HP Photosmart C6180 All-In-One InkJet Printer Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
