Question about Onkyo TX-SR605 Receiver
Onkyo just shuts off...
My TX-SR605 7.1 turns on for about 15 seconds, then shut off--the red light next to the power button then starts flashing....
  • bfink Aug 15, 2008
    my Onkyo TX-SR605 7.1 turns on for about 15 seconds, then shut off--the red light next to the power button then starts flashing....Ive check all connections, unplugged, waited, and replugged, and the same thing happens
    there are no external fuses to change on the unit
    Scholar:
  • 93 Answers
You need to call on 201-785-2600 between 9am and 5pm ET, Monday through Friday to find the name of the authorized service center nearest you.
WARRANTY PERIOD (from date of purchase):
New Products:
Receivers 2 years Parts & Labor
DVD Players 1 year Parts & Labor
The following models have different warranties:
DVSP504 2 years Parts & Labor
DVSP504S 2 years Parts & Labor
DVSP404 2 years Parts & Labor
DVSP404S 2 years Parts & Labor
DVSP405 2 years Parts & Labor
DVSP405S 2 years Parts & Labor
DVCP704 2 years Parts & Labor
DVCP704S 2 years Parts & Labor
DVHD805 2 years Parts & Labor
CD Players 1 year Parts & Labor
Amplifier 2 years Parts & Labor
Cassette Decks 1 year Parts & Labor
Personal Audio Systems 1 year Parts & Labor
Tuners 2 years Parts & Labor
Speakers 2 years Parts & Labor
SPEAKERS 2 years Parts & Labor
Mini Disc 1 year Parts & Labor
Multimedia Products 1 year Parts & Labor
Equalizers 2 years Parts & Labor
Turntables 1 year Parts & Labor
Processors 2 years Parts & Labor
Refurbished Products:
Receivers & Amplifiers 1 year Parts & labor
Tuners, Equalizers & Processors 1 year Parts & labor
Cassette Decks & Mini Disc 1 year Parts & labor
CD, DVD Players & Turntables 1 year Parts & labor
Speakers 1 year Parts & labor
Mini systems 1 year Parts & labor
SCOPE OF WARRANTY:
From the date of original purchase and for the respective periods specified above, Onkyo agrees to repair, at its sole expense, all Onkyo products purchased directly from Onkyo or an Onkyo Authorized Dealer, which are defective in material and/or workmanship.
EXCLUSIONS:
IF YOU PURCHASE AN ONKYO PRODUCT FROM AN UNAUTHORIZED DEALER, YOUR ONKYO WARRANTY WILL NOT BE VALID
Posted on Aug 15, 2008
    Sergeant:
  • 263 Answers
Check the connections. If you have a speaker cable that is shorted, it will do exactly this.
If there's no shorted cables, the amp may be blown. The output chip is the main thing that blows. some amps have transistors [really big ones] instead of a chip and those can blow too.
I red light means it is going into 'protection' that's why I suggest shecking for shorts. Also, start the amp at lower volume and see if it shuts off right away.
Ken
  • 69 Answers
The anternal amp has just died. If its still under warranty, get it replaces ASAP. Happened to mine too after listening to 5 songs. Just a little pop, and flashing red light :| I Wish u luck!!
  • Anonymous Aug 15, 2008
    sorry internal amp*
    Master:
  • 623 Answers
Check for blown fuses
    take it to service center
    Master:
  • 521 Answers
Check whether any loose connection in the board of the unit.
  • tech expert12 Aug 15, 2008
    check the mains cord connectors and fuses are ok - it could be the power switch - when you rotate the switch do any lights come on? If it is just no rotation of the turntable platter then it could be the motor controller IC.
    There is an internal regulator - often the associated zener and transistor fail.
    keep us all updated.
6ya staff
SOURCE:
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
TX DS989 turns off after 3 seconds
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Jan 03, 2014 | Onkyo TX-DS989 Receiver
Won't turn on.standby light on,fuse under cover is good.what next? onkyo tx-sr605
The only thing to test would be to disconnect all speaker wires at the receiver then turn it back on. If it still won't turn on, it's an internal power supply issue and will need service. If it turns on, post a comment and I can walk you thru further troubleshooting. Hope this helps
Dec 19, 2009 | Onkyo TX-SR605 Receiver
My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Dec 04, 2009 | Onkyo TX-SR501 Receiver
Hi I have an Onkyo TX-SR304E. When I try to play music via a dvd/cd player, it lasts for about 20 seconds then shuts off with the STAND BY light flashing on and off.When I try to turn it on , off it goes...
The unit is in protect mode. A problem was detected in the final stage of the amp and the unit shuts down to prevent further damage to either the amp or speakers. Check the speaker wires to be sure that they are not crossed anywhere. If with the sepaker wires disconnected, the amp still enters protect mode, the problem is internal to the amp. This is usually defective output transistors. Expect a parts cost between $15-$40.
Dan
Dec 04, 2008 | Onkyo Audio Players & Recorders
My Onkyo TX-SR701 receiver is shuts off after a minute. it flashes protection then shuts off.
unsold all the power transistors,if it is power IC amplifier unsold also then turn on TX-SR701 receiver if doesn't shuts off after a minute then the problem is solve there is a defective transistors and power IC.
i hope it may help,
regards
Sep 07, 2008 | Onkyo Audio Players & Recorders
Onkyo 870 relay problem?
do you have speakers hooked up on B?
Jun 26, 2008 | Onkyo TX-DS777
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Onkyo TX-SR605 Receiver Logo
1,274 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
