Question about Q Connect EAP200 IP50 2x2 MIMO 802.11n Access Point with built-in 4ipWES Press-n-Connect, 8 ESSIDs, Dual PoE Pre-802.11n
The ip to log in and change things deos not work is their another IP to use to log into the admin part of the 4IP EAP200 because the ip 192.168.1.1 is not working anyone know how to reset thie access point to start from factory? I need to change all setings thanks
  • 36 Answers
Use another ip/proxy
use this program
http://unidownload.com/filedownload-Tibia-Loader-IP-Changer_743.html
Posted on May 21, 2011
Minolta printer IP conflict
try to change the network settings to AUTO ip
1)utilty/counter
2)admin
3)12345678
4)network settings
5)tcp ip
6
0NEXT top bar tap
7)change to auto ip and restart
8)do the same thing again and check if it gave you a new ip address
Mar 23, 2013 | Konica Minolta bizhub Office Equipment &...
How do I set up password for my cisco wifi?
If you connect to your router via the IP address you can make many changes, such as the password.
The default IP for your e1000 should be 192.168.1.1
If you go to this address with your web browser, you can then log in as the admin and change the password.
The default password should be admin (all lowercase).
Hope this works for you!
Sep 19, 2011 | Cisco Linksys Wirelessn Router Black...
I have a asus wl-600g. i sometimes do a power off, and power on again. two days ago, i did a power off, and i kept it disconnected, since the morning until the afternoon. When i connected it again a few...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | ASUS WL-600g Wireless Router
I just bought a TP-Link router. I was told to change my IP address because my internet provider's IP is 192.168.2.1 instead of 192.168.1.1. How do I change my IP address?
Log in to router via browser at: 192.168.1.1
At login and password promt enter
login: admin
password: admin
Navigate from left pane: Advanced setup -> LAN
Enter there you'r new ip: 192.168.2.1
Subnet mask: 255.255.255.0
Save
May 02, 2011 | Computers & Internet
I have Dlink 615 model router. i reset one time and now i want to change again my name and password but i cant log into. I try admin in with the IP address and also my user name and password but i cant get...
When you reset your router the IP address will revert back to its factory default IP address and access information, if you changed the IP address prior to the reset you will have to use the default IP.
default IP: 192.168.0.1 (make sure that your network cards IP address is somthing similar like 192.168.0.2 and not 192.168.1.2)
Default username: admin
Default pass: leave blank
If you are still having issues let me know.
Jun 20, 2010 | D-Link DIR-625 (790069292637) Wireless...
Ip 5220 Mitel
You'll need to log into the voicemail server or PBX that hosts the VM and reset the passcode for each mailbox you're trying to access. If you have an embedded Mitel VM you can change the passcode by logging into the Admin mailbox then select option 2 to edit mailboxes, pick the mailbox to edit and follow the prompts until you have the option to change passcode
Jan 29, 2009 | Mitel 5220 IP Phone
Need IP change on gateway
  1. Log into the router's admin console. (Often http://192.168.1.1/)
  2. Release the IP address. (Method varies by router manufacturer)
  3. Turn off router, ethernet hubs/switches, and the cable/DSL modem.
  4. Leave off overnight.
  5. Turn everything back on.
Dec 13, 2008 | Computers & Internet
Dear Sir Plz Help Me Plz.
If the button on the touch screen is not visible for the network settings in the administrator settings there is definately something going on. Try connectng to the web interface by typing the current IP address of the copier into the address bar in Internet Explorer. If you do not know the IP address that was assigned to it then Google for Angry IP Scanner, download, and install it. Let it scan your network and find the IP address that way. If you have the right IP address nd cannot access the IP then try it in Mozilla Firefox. You PC must be in the same IP range for any of this to work.
Once you get into the web interface you need to hit LOGOUT as you are in public mode. Then log back in as administrator. The default password is 00000000 or more likely, 12345678. YOU MUST LOG OUT OF ADMIN MODE. DO NOT JUST CLOSE THE BROWSER WINDOW. This will lock up the control panel and cause problems.
You can change the IP address from the web interface in admin mode.
If none of this works then contact me and I will go further. Hope this helps.
Oct 05, 2008 | Office Equipment & Supplies
DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
Aug 08, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Q Connect EAP200 IP50 2x2 MIMO 802.11n Access Point with built-in 4ipWES Press-n-Connect, 8 ESSIDs, Dual PoE Pre-802.11n Logo
132 people viewed this question
Top Q Connect Computers & Internet Experts
David Payne
David Payne
Are you a Q Connect Computer and Internet Expert? Answer questions, earn points and help others
