Question about Schlage BE365-PLY BE365PLY626 Satin Chrome Electronic Security Keypad Elect
Need to change lock code but lost instructions. BE365 PLY 716
  • 963 Answers
Reprogramming BE 365:
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Posted on May 21, 2011
Testimonial: "Thank-you it worked."
Reset codes
This link will take you to the page that you need to get started:
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. "How can I program my electronic keypad lock when the instructions with the programming code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Sep 18, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I need instructions to reset the code
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
Sep 08, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Change code
Jul 11, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
How to change code
Good luck!!
Jul 10, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
How do i change the code???
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
Nov 27, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I have a schaeg BE365 and i would like to change the coad
There is a video on this page, showing how to change codes.
Nov 14, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
I can't find my key code card to my lock: MFG
Rather than list all the steps, which get lengthy when typing them step-by-step, I'll provide you with a weblink to the Schlage web site that has both pdf's and videos showing you how to re-program and operate your lock set. You can download the instructions to print and save for future reference too.
As you've forgotten/lost your master code, you'll need to use the restoring instructions to reset your lock to the factory default settings, so you can then reprogram new codes into your lock.
Basically, you'll need to open up the inside compartment and push the reset pin/button in order to clear all current code programs and then start over with inputing new codes, etc. Have your key with you, as you'll need it in case you accidently lock yourself out, while reprogramming the lockset.
http://consumer.schlage.com/customerservice/FE595_install_inst.asp
Hope you find this Very Helpful - Best regards!
Aug 12, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Schlage BE365-PLY  BE365PLY626 Satin Chrome Electronic Security Keypad Elect Logo
651 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
