Question about Motorola Mobility RAZR V3
Motorola razor ringer
My motorola razor has stopped ringing. It will vibrate but not ring. I have reset to factory settings and have had Radio Shack try. It is on the Alltell network. Please help....
Jessie L. Rosier
jl.rosier@yahoo.com
  • jlr030169 Aug 16, 2008
    Volume was my first try. IT DOES NOT RING!!!!!!
  • 37 Answers
Check the ring volume if it is fix to seven or not then try less no like 5 or four..
Posted on Aug 15, 2008
Stopped ringing and now just vibrating on incoming calls no sound on music either
Reset your phone to the default factory settings. If not remove the battery and reset. If this wont solve check the settings on the tones, if there is settings for ringing. If this wont work the ringer can be faulty. Might need to remove to check if this is a loose connection or a failure.
Feb 14, 2011 | Samsung S8300 Ultra Touch platinium-red...
Pebble ringer inop
Does it have a speakerphone function, does that work? It would seem that the second speaker is malfunctioning. There is usually seperate speakers for the earpeice and for the rigner/speakerphone. You could open the phone and make sure the speaker is sitting correctly, it could have rotated off it's contacts. But you may have to replace the speaker, possible found on eBay.
Mar 20, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Will not ring only vibrate
when you set the ringer to ring only will it ring?
on the side of your iphone there is a switch above the volume switch that is a ringer/vibrate switch
switch it and test
Jun 05, 2009 | Apple iPhone Smartphone
How do I increase my ring tone volume on my Moto Razor .?
You can set the length of your incoming ring to in the Call forwarding portion of the phone. Usually, it is set to 25 seconds. It can go as high as 30 seconds. To set the ringer to be longer or shorter, it goes by 5,10,15,... set of 5 increments. up to 30.
I would also recommend to use a factory set ringtone, set the profile to LOUD or OUTDOORS. With vibrate option on. Some downloaded ringtones don't play as loud.
Feb 10, 2009 | Motorola Mobility RAZR V3
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
Dec 09, 2008 | Radio Shack 433575 Cordless Phone
Ringer volume is low
Motorolas generally have a very low ringtone.The only solution is to find the loudest one on the phone and turn it up to the max.or alternativly go to settings-ring sytles-and change to vibe/ring.This will vibrate the phone first.if you phone is in your pocket or bag you should feel it vibe first than ring.
Dec 04, 2008 | Motorola Cell Phones
Ringer and vibrate at the same time
just select the ringtone and select the ring n vibrate feature
Aug 31, 2008 | Motorola Mobility RAZR V3
Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Will not ring or vibrate.
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility RAZR V3 Logo
118 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
