Question about Sony MHC-GX9000 CD Shelf System
I have the MHC-GX9000 and Im not sure what settings to place my EQ levels at? The mid, the low and the high? Any kind of help here will be appreciated! I've been adjusting it for two days and I can't get it right.
  • Sony Master
  • 6,771 Answers
In most cases the mid will give the full sound, from that position you can tweak it slightly up to bring out more bass, middle tones, and highs.
Posted on May 21, 2011
I have a kustom kpm7200 that sounds distorted even at low levels.
That is like asking which grain of sand is red. Try checking your input levels, if they are to high this is exactly what you will get. Set all EQ settings to mid point. If the problem is not resolved take it to the tech for repair.
Mar 03, 2015 | Audio Players & Recorders
AIWA CX NAJ70 music at normal level but singing is faint in the background
That doesn't seem like a problem with the system/ But make sure any eq settings are all at 0 and your mids arent all the way down or much lower than your high and lows. But if thats not it then it has to do with your music, try a different song. a different cd all together
Feb 04, 2012 | Aiwa Audio Players & Recorders
I have the MHC-GX9000 and Im not sure what settings to place my EQ levels at? The mid, the low and the high? Any kind of help here will be appreciated! I've been adjusting it for two days and I...
  • It's all by ear. Every person is different. I like to turn the low up all the way. That's the base. I turn the highs almost all the way up and the mid levels midway between the middle and all the way to the top. above midway. This makes it loud with bass and the high pitch of a tweeter so you can hear the words and instrumentals and the mid levels can be heard still. This is best served for rock and rap. Classical and jazz you want the highs all the way up and the mid levels about midway and the lows about half way between all the way and midway. this make it loud but puts the emphasis on the instrumentals.
Regards, Tony
May 21, 2011 | Sony MHC-GX9000 CD Shelf System
I have a Sony mhc gx9000 unit but I don't have da original speakers or wires how can I use it with normal speaker wire. Speakers
I would recommend against it. The system is sold as a package with proprietary connectors for a reason.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX9000
You'll notice there are no facilities for balancing the relative volumes in the electronics. After-market speakers of unknown sensitivities would be impossible to match if it could even drive them sufficiently loud.
Jan 16, 2011 | Sony MHC-GX9000 CD Shelf System
Setting up rta on a driverack pa, system willnot
As far as I know, you just turn the dial so that you can hear the pink noise at what you expect to the the normal listening level, hit "next page" then the system starts "listening" and adjusting automatically. If you set the RTA to high resolution it can take a while. At this point you shouldn't be trying to hit next page. Just wait for a while. Maybe 5 to 10 minutes if you're on high resolution, depending on your room and setup. Let it go through and EQ. After a while you'll get a black progress bar at the bottom of the screen, sort of like a file download progress meter. Let it finish. If it's taking too long check the manual for how to change the auto eq to low or mid resolution.
I hope this helps. From your post I can't tell exactly what's going on. Reply with more info if you like and I'll try to help again.
Dec 06, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
How should I place the tie mic
Typically you want to wear the mic 6 to 8 inches below your chin clipped to the lapel area. It seems in this case it has more to do with EQ and speaker placement. If you can stand behind the speakers while using the mic. The sound bouncing back and forth between the mic and the speaker is what causes feedback. Also try setting the mic channels EQ with the following settings.
Turn Lows down to about 7 to 9 O'clock
Play with Mids to match actual source, but never boost above 12 O'clock
Keep highs around 10 O'clock (boosting highs increses chances of feedback.) If to muddy sounding keep highs aroun 12 but not over.
Good Luck
Oct 08, 2009 | Audio Players & Recorders
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
Setting low pass and bass eq
Hello, i have a hifonics brutus also, in the manual it states to set the eq at half way, so that there is no clipping or at least to prevent clipping , the eq will make the bass punchier, if you do go pass half way, i would recommend to readjust your gain settings, also check your head unit settings and make sure everything is flat, bass, mid bass etc. example i had my eq past half but i had my gain at mid way, it was hitting hard, then i tried turning the eq all the way down and the turning up the gain and the bass was smoother so it depends where you set it, and what settings you have on your head unit tone control (bass, treble etc)
May 15, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Bass frequncy
Although I am not familiar with the Zoom HD 8 Track I am a former sound engineer so may be able to offer some general advice.
Firstly, because the wave pattern of low frequencies is very long, there are a number of things that will greatly effect bass response caused by standing waves.
1) The position of your bass monitors. Ideally these should be low down but not directly on the floor, especially if the flooring is wooden.
2) Try your monitors/speakers at a slightly different angle. Bass can bounce off walls, back towards the sound source and phase out the signal, rather like a noise cancelling system.
3) Try listening to the sound in different areas of the room. You will be amazed at how the sound pressure level will vary, simply by you moving from one position to another.
4) Never put bass tracks exactly at centre, always offset them slighly by a few degrees left or right.
5) Do some of your mixing using headphones, you will not have to worry about standing waves. But remember that things sound very different on speakers in free space.
Strangely, the reason you are getting distortion when you turn things up is probably because your bass is on the verge of over modulation to start with. Really bass is felt, not heard. You could try is to decrease your mid and high frequencies a little. The ratio between high frequencies and low ones will then increase by default and your bass may feel heavier.
What are you mixing?
Dec 31, 2007 | Koss EQ50 Home Equalizer
Fostex mr16 eq/presets
In short - No. The Eq menu is the only way to affect the frequency levels on the inputs, but if you select stereo buss and listen to the inputs, you can hear the effect of each Eq on the relevant input.
Dec 22, 2007 | Fostex MR16HD/CD Digital Recorder
Sony MHC-GX9000 CD Shelf System Logo
55 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
