Question about Ace Hardware Ace Staple Gun
My new ace AIRCRAFT ALUMINUM staple gun seems to be locked. the silver lever inder the handle won't go completely down
BobbyR1234
  • 173 Answers
SOURCE: directions to open and load a Black&Decker PowerShot stample/brad gun
Check the following link in which you may find a pdf manual for your product. Just click on the "link" and it will take you to the google search for your product. Hope this helps and let us know if you need further assistance.
Posted on May 30, 2008
danny_murray
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
SOURCE: Is the Ace Hardware #22084 Staple Gun the same as
Found a friend who had an Arrow T-50 stapler and compared staple sizes - not the same.
Posted on Feb 18, 2009
  • 240 Answers
SOURCE: how to remove jammed staples in staple gun?
Pinch the clip located on the end of the Magazine Unit Pull out the Magazine Unit Remove jammed staples from the channel. You may need to use long-nosed pliers . Make certain that you are using correct size staples. Close Magazine Unit.
Posted on Jun 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
Staple gun seems locked...brand brand new
look for a small button on the side that locks the handle down for safety and transport. It will be a slide button so push the handle down to release it and slide it back
Aug 03, 2013 | Arrow Tools & Hardware - Others
I am trying to staple screen on 1.5 inch pine frame with 1/2 staples, but I have to set them with a hammer. Am I expecting to much or is there a way to adjest it to run them in the who way /
I have found that staples will set well only if I use the palm of my hand to hold the front of the stapler down tight against the material as I operate the handle.with my other hand. Without holding it down this way the stapler tends to recoil a bit and the staples don't set all of the way. If that doesn't solve it for you, you could try using 3/8 staples, since the screen material is of negligible thickness. Good luck, Al K
Jun 01, 2011 | Ace Hardware Ace Staple Gun
How do you open/refill this stapler?
Push the top of the lever located on the back of the stapler.It will pop out on a spring. Slide a new strip of staples in and push spring/rod assemble back in until it clicks into place.
May 31, 2011 | Ace Hardware Ace Staple Gun
I have an ACE aircraft aluminum stapler... I bought Ace Heavy Duty Staples 3/8" 10mm Narrow Crown Arrow T50 staples but cannot get the arm to load with them on it.
Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
Jan 09, 2011 | Ace Hardware Ace Staple Gun
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Reloading ace 22084 staple gun
Hello there:
Oct 03, 2009 | Ace Hardware Ace Staple Gun
Power shot stalel gun
there should be a silver clip thing thats over the mag that holds the staples try sliding that down and then it should open 4 you
PLZ RATE THIS IF U FIND IT HELPED YOU IN ANY WAY TANKS.
Jul 18, 2009 | Ace Hardware Ace Staple Gun
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Dec 03, 2008 | Ace Hardware Ace Staple Gun
Ace Hardware Ace Staple Gun  Logo
134 people viewed this question
Top Ace Hardware Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Ace Hardware Tool and Hardware - Other Expert? Answer questions, earn points and help others
