Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
I have no sound/ I have a picture my tv is hooked up with coax cables- i have unplugged the tv that didn't work the volume is all the way up on the tv--- we have reset the factory defaults-- no surround sounds only the tv
  • 373 Answers
Just to mention that if you have Directv or Dish hooked to the TV, you may need to unplug the satelite receiver for a minute and plug back up. I have seen this happen so many times and people think their TV is at fault. And of course is the possibility of the speakers being cut off in the Sound menu which it looks like you have checked. Lastly, the problem would be in the audio board which Ebay has currently for $18 and shipping $5. Put the model number in the search field at Ebay and scroll down to the audio board.
Posted on May 21, 2011
How do i hook up mono tv with eterxnal speakers with a dvr box
If the DVR has RCA-type connectors, yellow to yellow for picture, and white to white for sound. Tune tv to line input.
If the DVR supports outputting everything on coax, use a piece of coax cable, and tune tv to channel 3.
Your coax cable from wall has to go into DVR first, then out to tv.
Aug 26, 2014 | RCA F32650 32" TV
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
I have BOSE speakers plugged into a small lcd tv. when the tv is off, I'm still hearing cable audio. why? i'll clarify. my tv has rca jacks connecting it to a couple of small bose speakers. sounds...
Your TV output is a pass-thru from the coax cable then. The only solution- turn the volume down, or unplug them.. Or get a cable box. A VCR may work as a temporary cable box, and if you have a remote for it, you should be able to just turn off the audio at any time with a VCR remote. (unless the VCR also has a pass-thru only audio output)
May 25, 2009 | Audiovox DVD Player FPE1505DV
NO volume
often people make the mistake of hooking their devices to the tv using more than one input.  a cable box for example may have many different types of outputs but you are only going to use one to the tv (preferrably the highest quality connection). try switching the inputs on the tv to see if you get the same picture on two different inputs.   If using s-video, you will also need a red & white RCA cable for audio.  The order of video cable quality from lowest to highest is this: Coax(screw on), Composite(yellow,red,white), S-video(Round)+(red,white), Component(video=red,green,blue), HDMI(carries HD video & sound)
Feb 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Volume won't work in satelite mode
A few possibilities - try volume + on satellite box itself/reset satellite box
Are you using coax or RGB cables? unplug and replug composite or component audio cables if using those
Aug 19, 2007 | Hitachi 51F59 51" HDTV Projection...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
90 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
