Question about GE Energy Star WCVH6260F Front Load Washer
GE front load washer
After I wash The clothes completly and have the washer go throhg the spin cycle, the clothes are still soaking wet. How do I empty the lint trap?
  • 3 more comments
  • jimroffey Sep 16, 2008
    I have a similar problem.  The washer is not spinning well.  My thought is that it is sensing that the load is out of balance so it stops and spins slowly to try and even out the load then tries a faster spin (not THAT fast) then repeats the cycle.  After about 15 mins, turns off and the items are still wet; regardless of the size of the load.  The fix describes sounds intriguing but please explain what we are doing by pulling out this component and why the towel; parts?  water?  Thanks!
  • OsmondTee Sep 20, 2008
    Yes, I have the same problem! A little upset and its fairly new, thought I was buying on of the best.... same problem; it doesn't happen all the time but I do have to put the wash on spin again to get the clothes dry enought to put into the dryer. Sometimes the second time
  • rlawlor Oct 03, 2008
    not sure what to do - very random...
    i am going to open the panel noted and see what i can see... also not sure of where the "filter" is that was noted in a related issue.
    I will go back and let others know if i fix it.
  • doggiedoc May 02, 2009
    I have a different problem, but the REAL problem is the GE phone service "technician." As she is trying to describe how to open the panel, she is trying to tell me just to insert a coin at the top "slot" and pop it open. Doesn't understand when I tell her there are three screws on the bottom holding the panel to the washer body. Finally, both of us in frustration, she gives up and tells me the only other option is to send a service tech in ONE WEEK to fix it.
    Now that I know you actually have to take the screws out, I'll do it my own damn self.
  • Anonymous Mar 12, 2014
    lint trap on ge gtwn2800 washing machine
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Posted on Aug 28, 2008
My washer spins the load but does not spin the clothes well, the clothes are left soaking wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | GE Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
499 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
