MS 7522 lights up power no blink and won't post.
bronk50
  • 27725 Answers
SOURCE: I've got an intel db43ld
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Aug 30, 2011
SD Tech
  • 14553 Answers
SOURCE: popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Posted on Jun 16, 2012
twistedki245
  • 35 Answers
SOURCE: Ms 1745 mother board won't power up
This isn't much of a solution, but I can tell you one thing. If the mother board smells like ozone, it's fried. Sometimes you can see where by comparing the clarity of the circuit routes. Sorry if this isn't much help,but if the board is no good then searching for a fix is pointless. GOOD LUCK. Hope it's something less severe.
Posted on Jul 02, 2012
gopakumarg43
  • 74383 Answers
SOURCE: power button won't turn tv on. light keeps blinking on and off
Main board to your TV is faulty. Check the chroma and video processing section. In most cases, it will be due to an IC fault.
Posted on Jul 24, 2012
SOURCE: hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Posted on Sep 15, 2012
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
LCD Won't Power On
Blinking of power light is fault indication. From the number of blink that occur at one time switch ON, you can get an idea about the faulty circuit side. These are called blinking codes. To know more about these blinking coded, visit the site. It has details about blinking codes to many brand TVs. Pull up older posts. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Apr 22, 2013 | Televison & Video
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Power timer light flashing, won't come on
Flashing of power LED are fault indications. You have to count the number of flashes occurs at one time. Check this link for more details about the blinking codes. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name first.
Dec 22, 2012 | JVC AV-32D305 32" TV
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here slinteriors@yahoo.com
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have a mitsubishi ms-65511 and we had a poweroutage for several hours today and now the tv won't turn on and I am getting a continuous green light of death ... HELP
Thats caused by weak capacitors on the DM board which cannot recharge after the power has been restored. Very inexpensive repair . The WS48511 - WS55511 DM repair kit from www.tvrepairworld.com has the capacitors and the CD with repair instructions which should solve the issue of the steady blinking green light.
Oct 11, 2011 | Mitsubishi WS-65511 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I upgraded to windows 7 now my integrated microphone no longer works
Hi l d gisme...
Go to the manufacturer website,then go to the support section...
look for driver downloads...audio driver...
Download and install it...shut your computer off and restart...you should have sound back.
I would have had your driver webpage, but you gave me no info about your computer...sorry
Please take time to rate me
Sep 12, 2011 | Toshiba Computers & Internet
Need a owners manual for model RP-7958
Hi riamb9...
Sorry I could not come up with a user manual for your RP-7958 there was only one page about this remote.
But it did contain a phone and address that may have a manual for your remote..go to the following webpage, and scroll down to the bottom of the page to get there phone number and address.
Give them a call and they may be able to ship you a manual for your remote
Replacement Remotes ' Phone: 336-924-8787 ' Fax: 336-922-7522 Address: 4945 Reynolda Rd, Winston Salem, NC 27106
Phone: 336-924-8787 Fax: 336-922-7522 Hours of Operation: Mon-Fri 9:00AM - 5:30PM EST Address:
(Returns Department)
Replacement Remotes
4945 Reynolda Rd.
Winston-Salem, NC 27106
Replacement Remotes ' Phone: 336-924-8787 ' Fax: 336-922-7522 Address: 4945 Reynolda Rd, Winston Salem, NC 27106http://www.replacementremotes.com/RCA/Buy-RP7958A-54022-Remote-Control.html
Sep 04, 2011 | Audio Players & Recorders
My MSI MS-1683 Laptop With Windows 7 Home Premium won't boot up right. When I hit the power button, it loads to the screen that says "MSI" and then to a screen that has an underscore that...
That blinking underscore is the way in which the laptop's BIOS is telling you that it didn't find any Windows to boot to - it was completely corrupted.
The only thing left to do is to reinstall it.
May 29, 2011 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
