Question about Canon Cameras
Lens error.. lens is stock up - Canon Cameras
  • Canon Master
  • 43,501 Answers
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Posted on May 21, 2011
Eject and load error
Most common cause for this is dirty lens, try a cleaner disk, possibly the one with liquid cleaner.
If this does not work , providing that the engine is spinning you may need to replace the lens inside
Mar 15, 2008 | Car Audio & Video
It seems the lens is stock. it was working just fine and suddenly got stock out. It doesn't come in or move any more. There is a E18 on the screen. Can anyone help me?
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Dec 14, 2009 | Canon PowerShot S2 IS Digital Camera
Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 15, 2009 | Canon PowerShot SX100 IS Digital Camera
The lens keeps going in and out and says lens error
was it ever dropped or stock somewhere moist? above all, not good news. The message indicates that the lens housing has beendented or otherwise damaged, preventing the camera from functioning.Your camera will require professional repair.
http://photo.net/nikon-camera-forum/00CW3S
Sep 11, 2009 | Nikon Coolpix S210 Digital Camera
Lens mount plastic is broken on Lens
Unfortunately your lens is one of the kit versions which were built as cheaply as possible with a plastic lens mount. They were never intended to be repaired, but to be fair they usually seem to last quite well on the 18-55mm versions but the 18-105mm is heavier and longer and I've found that the plastic mount is particularly intolerant to any handling errors on this lens.
A professional repair will normally cost more than the lens is worth, but you can sometimes buy new replacement mounts.
Use your favourite search engine to look for part number 1C999-488. Unfortunately they're rarely in stock whenever I've needed one. You may also want to search for a scrap lens with a good mount which you can replace yours with, but scrap lenses of the correct type usually have faulty or badly worn plastic mounts as well.
Carefully assess your lens before making the repair: unless it's in perfect working order in all respects except for the broken mount then you'll be better off buying a new or used complete replacement lens.
Aug 31, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Bought new discs will not initialise dvd -rw error message could not format due to error detection
I had a similar problem with CDs. The cure in my case was a new drive. It is possible that the lens on the laser is dirty in which case it should be cleaned. Your local shop should stock cleaning kits,
Feb 28, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Error message for 2001 Tahoe stock CD Player
try using a lens cleaning disk
(what is the error_)?
Dec 29, 2008 | 2001 Chevrolet Tahoe
Lens Error and Dim
thank you.
i can see the shutter (blades) partially open.
Jan 25, 2008 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Lens stock out says to reset camera
internal lens barrel has been damaged,so lens could not move therefore it gives lens error.
this problem due to damaged gears or barrel dislocations.
not by dust,it is repairable..
Nov 20, 2007 | Canon PowerShot SD600 Digital Camera
Cameras Logo
16 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
