How to connect a computer to the television - Televison & Video
  • 36 Answers
Posted on May 21, 2011
How to connect Hi-sense plasma television to dell windows 8 laptop? Can Hdmcable be connected if not what are the other options?
Computer HDMI ports don't usually pass the sound from the computer on the cable. You have to use a cable between the PC and the PC audio IN connection on the TV. This is usually a 3.5 mm stereo audio cable.
Sep 13, 2014 | Hisense TA42P40M 42 in. Plasma Television
Tip
How do I connect my laptop to my TV
Connecting your laptop or PC to your tv is pretty simple. Just check both your computer and television to find out what connections they have in common. If by some chance you have no connections matching up, you can always buy adapters to make your connection types match.
Once you've passed the stage of physically connecting your computer to your television you'll have to select the correct input on your TV. Just like when using your DVD player, select the input that your computer is connected to using your remote. This input might be called something like AV1 or AV2. You should see this on the television screen.
The following is a list of the different types of cables/connections you will have to choose from with picture quality ranging from highest to lowest :
on Dec 26, 2010 | Computers & Internet
Lc37aa1m
1. Buy a monitor to computer cable (VGA cable),
2. Connect one end to the television,
3. Connect the other end to the computer (video port),
4. Turn on both of the television and the computer,
5. Select the television input (VGA or XGA) using the television's remote control device.
Dec 25, 2013 | Sharp Televison & Video
Attach computer to television
you would need an HDMI cable to connect the visual of your computer to your tv. you would need to connect from the headphones part to the audio in section to hear wats on the computer
Nov 08, 2012 | Vizio GV42L 42 in. LCD Television
Good evening. When you connect the computer system unit to a television sharp lc-32a47e AQUOS not hear the sound. Explain why. Thank you
The reason that you may not be getting sound is the cable you are using to connect the computer system to the television. Without that specific information I must speculate that this is the case. The only cable that carries both video and sound is hdmi. If you are using an hdmi cable then you must go to your compute system's sound properties and designate hdmi as the choice. Even if you are using dvi to hdmi it will not carry sound. A VGA (an RGB) cable will not carry sound.
On this television in particular there is input #7, which has an input for the computer system and an audio jack so you would connect an audio cable between the computer system and the television. It does not appear that you have to designate input #7 for audio to the television when doing this. It appears that the sound will come through automatically.
Feb 08, 2011 | Sharp LC-32D6U 32 in. LCD Television
How do I connect my computer to my tv so I may view internet on my tv?
To connect your computer to your television, you will have to get the VGA cable for your computer and connect it to the back of your television, then you connect it to the inlet/port that is on the computer, that is the port where you connect your monitor, then you go to your television and select the AV mode, then you will be able to view your computers work on the television.
Take care and good luck
Dec 12, 2010 | Vizio VF551XVT 55 in. HDTV
How to hook up your computer to your tv
You will need a TV tuner or Video card with a built in TV tuner.
Nov 20, 2009 | HP Pavilion m7580n PC Desktop
TV will not work when connected to laptop with av cable
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpg This information is from the owners manual for your model Sony (PCG-GRZ610) PC Notebook computer found on page (57) has a diagram and procedure for making the correct connections. You must make sure you have the correct connection cables and have set both the television and computer for external signal output source (notebook).External signal input source (television). The cable connection is listed below and follow the web page link to see the correct procedure for getting the laptop computer and the television working together. This procedure is explained in the notebooks owners manual on pages (112) (113) (114) you will also need to look in the televisions owners manual to see the procedure for switching the input source to external, so it can see the computer's signal. The owner manual copy is listed as the user's guide. You will also find customer service available on this web page. They will be able to help you with any problems you might be having with the set-up between the computer and television not explained clearly to you in the owners manuals of the laptop and television. I hope this information helps you solve the problem of making the connection between your laptop and television. Thank you for using FixYa and have a nice day! http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCGGRZ610
May 07, 2009 | Sony VAIO GRZ610 Notebook
Connecting Television to Computer
does the tv have an hdmi, fpc or vga connector? these are the prefered inputs from a PC.
Dec 06, 2008 | Televison & Video
Connecting a pc to a television
if you can see the background screen it means that you have to drag the programmes off you computer monitor off the screen and it will appear on the tv.
Sep 29, 2008 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
