I have a zenith li5v36 lcd tv...the picture is strong but it takes a long time for the tv to come on...sometimes up to a whole day...can i get this issue fixed...or is the tv a goner!!!
    Problem Solver:
  • 17 Answers
This is a common event. Most probably some capacitors are going bad in the power supply. Have them replaced before more serious damage occurs..
Posted on May 21, 2011
My TV works fine with excellent sound and picture quality but the picture comes and goes?
Check all cable connections, if known to be good, then I would think it is a internal board issue. these boards some times crack connection from heat cycling, boards flex hot and cold.
Feb 02, 2016 | Element Electronics FLX3711B 37 in. LCD TV
I have an ILO-32HD and the picture comes and goes on it. Sound is great. Sometimes it goes for days without any problem, then it will do it many times a day. I know it is the TV because the other TVs in...
Tv power supply board have problems,not giving the wright voltages to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | iLO 3200 32 in. LCD Television
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
My zenith lcd tv has lost its blue tint. most
the light polarizer on the blue lcd panel is fried due to excesive dust and heat, and therefore need to be replaced. unfortunately, zenith may not sell individual parts of the optical engine, so you'll have to replace the whole optical engine.
Dec 17, 2009 | Zenith E44W46LCD 44" Rear Projection...
The picture is taking longer and longer to come on. It's not a consistent length, last night had it on several hours, it was off for an hour and a half, turned it back on and it took over 90 seconds for...
if you can get another one for a reasonable i would certainly consider that. the cost to get these lcd's fixed sometimes is not worth it. you seem to have more than one problem with the set.
Oct 30, 2009 | Zenith C32V37 32" TV
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Tv goes blank
The effect you described sounds a lot like a failed solder joint.
There are points on the circuit board that are subjected to heating and cooling each time the set is powered up, then down.
The solder joints near these areas can fail from metal fatigue as will any metal that is forced to expand and contract repeatedly.
These fractures are minute and can often only be seen under magnification.
Once found, they are simple to fix; removal of the old solder and resoldering will restore electrical contact in seconds.
If you can find a gray-haired tech nearby who is retired, maybe early since repair is a business stagnated by cheap labor in Asia, he/she will know where these areas are and can robably get rid of your lottery-like operation.
Or, if you have way too much time on your hands and are willing to buy a decent soldering iron and dig into the guts of your set, you can probably find the problem yourself.
While semiconductors do fail (sometimes for the same reason), since the set does sometimes restore itself, it isn't likely that any of those has died.
I would be torn to toss the set if it is otherwise OK for the simple reason that if repaired, it may outlast 80% of those bought in the last 2 years.
It is amazing the number of problems that are happening on new, sophisticated sets and it is traceable to lousy quality in parts and assembly.
I have one LCD set I will probably junk this year that is only 2 years old, flawed when I bought it new, and has a failure producing a vertical black stripe that would require replacment of the $4-500 panel.
Junk - Specifically, WALMART junk.
Jul 12, 2008 | Zenith B32A24Z 32" TV
Zenith z50px2d
Check your input connections, especially the HDMI (if in use). I have found through personal experience that the weight of the cable and any small vibration can be enough to loosen the connection and leave you a blank screen. The manufacturers would have been smarter to have all the inputs face toward the floor at the bottom of the set (like the power cord). Anyone who has mounted their set to the wall will understand what I am saying.
That being said, you may be better off saving your money and buying a new LCD TV. The Zenith sets have proved to be a ticking bomb. If you Google "pop" and "z50px2d" you will read a number of posts on various boards that indicate that the Zenith plasmas have about a 2 year life expectancy before they are in need of some very expensive service. And frequently even after they are serviced are prone to further failure.
Someone pointed out to me not to long ago a valid fact: LCD technology has been around since the pocket calculator and therefore much less prone to unexpected failure than the relatively new plasma technology. I just wish someone had told me that 2 years ago when I ponied up $3000 for my Zenith z50px2d that blew out a few days ago.
Nov 01, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith lcd-tv Monitor model number L15V26C
I need an ac adapter for my Zenith L15V26C LCD TV.
Feb 12, 2007 | Zenith L15V26 15.1 in. HDTV-Ready LCD...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
