Question about Hayward 1 Hp Max - Flo Swimming Pool Pump
PUMP SEAL LEAKING\r\nNEED REPAIR MANUAL - Hayward 1 Hp Max - Flo Swimming Pool Pump
    President:
  • Hayward Master
  • 1,378 Answers
If you do have the Max flow the manual is here.
If not, find the correct model here and select it...then go to the manual page.
John
Posted on May 21, 2011
How to repair a front pump seal on a '99 cadillac deville concourse
You did not specify which pump. If it's the water pump, you will probably need to replace it, as it is probably the shaft, not a pump housing seal, that is leaking. If it is the housing seal, you will still need to pull the pump to replace it - there is a special tool for this.
Dec 24, 2016 | 1999 Cadillac DeVille
Western flostat pump leaking fluid between motor base and pump seal?
replace the pump seal
there is a bellows type carbon on ceramic seal that over time the rubber cracks , or if run without water will damage the carbon seal surface on the ceramic base
any pump or irrigation shop can affect the repair
Dec 13, 2016 | Plumbing
How do I repair a leak coming from water pump gasket?
If it's leaking from the gasket you'll have to replace the gasket. If coolant is leaking from the hole in the water pump body the water pump seal is leaking. The pump will have to be replaced if the seal is leaking.
Sep 12, 2013 | 1999 Plymouth Voyager
Pantera pool filter manual
Exactly where is the pump leaking?
If it is leaking between the wet end and the motor then you need a new shaft seal sometimes referred to as a mechanical seal.
You will need to know the brand of your pump when you start searching for the replacement.
Rod
US Parts Center
May 06, 2013 | Hayward SAND FILTER, PRO SERIES
Speed Queen washing machine pump, part no 27041,
The impeller shaft has a water seal. This seal wares out after a period of time. The hole allows water leaking through the seal to escape. There is no known repair to this problem except replacing with a new pump. Trying to block up the hole is a waste of time.
Apr 27, 2012 | Speed Queen Washing Machines
I have a corner whirlpool tub and the pump is leaking water when it is on high. I am trying to find a parts supplier to repair myself
sounds like you need maybe pump union o-rings, part # o-49 or the seal might be leaking. If the water is leaking between the plastic wet end and the motor then it is definitely the seal kit which costs about $30 however on a bathtub most pump mfg have quit making replacement parts for them. You will most likely need a new pump in that case. If you can let us know what brand of pump we can assist you in repair or replacement.
US Parts Center
Aug 08, 2011 | Whirlpool Home
Water leaking from pump
Hi thomasgor192...
If you have water leaking from the pump then you have a faulty seal that must be replaced or a gasket leak or failure.
Turn on your pump, bring it up to pressure and try to locate the leak with a flashlight and then you may be able to repair your problem by replacing your seal or tightening your gasket or replacing it.
Please take time to rate me
Jul 03, 2011 | Home
Water leaking beyween the empellarand moter housing
pool pump repair guy in longwood florida , here to save the day.. Ok what you have is a bad shaft seal (90% of the time) OR tank crack or a cracked seal plate or a bad gasket or o-ring.. look at the link and it wil help you ID your pump and take it apart. prim that pump after a repair !!! www.poolmotorrepair.com/
the cost of a shaft seal
Jan 15, 2011 | A.O. Smith SQ1102 Pool Pump Motor
Water leaks between motor and pump can't get motor off
hello there this may help you out ok
best regards michael
Leaking Pump in a Whirlpool DU810DWGQ1 Dishwasher by Samurai Appliance Repair Man
function ReferThisPage779b7841ed943a9e880964fef6da376b(){var rtp;rtp = window.open('http://www.tellafriendking.com/refer/?URL='+escape(document.URL)+'&CODE=779b7841ed943a9e880964fef6da376b&JS=1','_blank','width=350,height=530, resizable=yes, status=yes, scrollbars=yes');if((null==rtp)||'undefined'==typeof(rtp) ){alert( 'The \'tell a friend\' window was prevented from opening.\n\nPlease temporarily disable your popup blocker.');}rtp.focus();}document.write(""); rn-spa-g.gif document.write(""); 3548679745_8c188ff0d2_m.jpgLeaking Pump in a Whirlpool DU810DWGQ1 Dishwasher
These are cheesy, inexpensive dishwashers that are prone to leaky pumps, as shown here (click the pic for the larger, annotated view).
3548734637_17f81a0e1b_m.jpgWhirlpool DU810DWGQ1 Dishwasher Pump and Motor Diagram
The problem is usually a leaky shaft seal kit, shown here as Items 7 and 8 (click the pic for the larger, annotated view).
Fortunately, the shaft seal kit is inexpensive; but it can be a ****** to install, depending on how much rust you’re dealing with. May require a destructive removal of the impeller, too, but ain’t no thang ‘cuz the shaft seal kit comes with a new impeller. Here’s a nice, purdy picture of a brand new shaft seal kit. And just to help motivate you a little more, the money you save from replacing just the shaft seal vs. replacing the entire motor-pump assembly is well over a Benjamin. So you go ahead and drill, cut, and chisel all you want on that old impeller!
wpl-dw-horiz-pump-shaft-seal-kit.jpg And Whirlpool just came out with a spiffy new DIY repair manual for this dishwasher, which will assist you mightily in the many repair adventures you are certain to have with this dishwasher:
whirlpool-dw-diy-manual.jpg To learn more about your dishwasher, or to order parts, click here.
Sep 14, 2009 | Kenmore Dishwashers
My estate washer is leaking water when we turn it on. It is not holding any water in the tank. Any suggestions what I should look for and fix myself. Thank you
If the washer leaks when you turn on check these:
* Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
* Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
* Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
* Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Sep 02, 2009 | Whirlpool Washing Machines
Hayward 1 Hp  Max - Flo Swimming Pool Pump Logo
102 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
