Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
Compaq Presario SR1303WM, I keep getting a popup bubble saying my virtual memory is low and my computer runs slow. Can this problem be fixed?
    Sergeant:
  • 281 Answers
This is very easy to fix,You can buy and add more memory with this tool; http://www.crucial.com/
It will scan your computer and give you information that you need.Memory is the best bang for the buck.It is all so easy to change it your self by going to start> control > panel > system >In the left pane, click Advanced system settings.This is the Microsoft.com page that explains the whole procedure.
http://windows.microsoft.com/en-US/windows-vista/Change-the-size-of-virtual-memory
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 21, 2011
Compaq presario sr1320nx slow virtulal memery low
Each program that is simultaneously running on your computer is using some of the RAM. If the sum of the sizes of those programs is larger than the total amount of RAM installed on your computer, then Windows writes some of the contents of RAM to the disk-drive (compare to moving a book off the kitchen table onto the bookshelf, to make room for a different book on the table).
When Windows is finding that "too much" of the RAM has been written onto the disk-drive (because you are running "too many" programs at the same time), then you get the "low virtual memory" message. Windows will reserve additional space on the disk-drive, but this will take up to 1 minute.
Sep 26, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
My computer displays an insufficient virtual memory notice, even if i am only running internet explorer
You just try increasing your virtual memory in your system. Right click on My Computer, click the advanced tab. Under Performance click on the button called settings. In that popup, you will have an option to edit your virtual memory. Try increasing it and then see whether the problem persists or not...
Aug 03, 2010 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Opening programs is so slow virtual memory running low
which operating system you are using and what is the ram capacity? and onemore thing to check what is your virtual memory capacity. for that
Right click "mycomputer" > properties > advanced >click settings on performance > in advanced tab > increase virtual memory file size.
generally its size is ram capacity * 2 (ex: for 512mb its virtual memory size is 1GB) check that and we can increase the file size also.
Jun 23, 2010 | Compaq Presario 5000 PC Desktop
How to change windows 2000 to the new one?
to make your computer fast follow these steps
1. remove all files from %temp%
2. remove all files from prefetch
3. right click on my computer
4. click properties
5. select very first option where it says Performance
6. uncheck all visual effects
7. click apply
8. select advance
9. select virtual memory
10. set virtual memory to recommended
11. click apply
12. click OK
13. restart your computer
and less visual effect you use more faster your pc will be as visual effects consume lots of memory. Download Malware Bytes from
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
and follow instructions to install
run malware bytes to remove trojans, broken registry entries.
restart computer
May 04, 2010 | Compaq Presario Notebook
Low virtual memory and slow loading
Go back into the virtual memory settings, change the settings using the custom size adjustment.
Change the initial size to 650 and the maximum size to 1200, make sure nothig else is checked and click set and then ok and exit out of all windows and reboot the mechine. let me know what happens and if the bubble popup disapears. cheers.
Mar 25, 2010 | Computers & Internet
Compaq presario Sr1303wm power will not stay on...but when I unplug the p7 power supply wire from the motherboard it does stay on...please help.
What does the P7 connector control? How many wires come out of it and what are their color codes? We should be able to fix this. Write me back.
Nov 30, 2009 | Compaq Presario sr1303wm Computer - AMD...
Virtual memory
The topic of Virtual Memory can be confusing for some folks, but I'll try to explain it as best I can (starting with the basics).
RAM, or, "Random Access Memory", exists in every computer. RAM are actually pieces of hardware (chips) and are used to store temporary data. The temporary data is then used for computation by the CPU (Central Processing Unit) at a later time.
So, for example: when you double click to view a movie file on your computer, it is first loaded into RAM (a chunk at a time), then moved to the CPU (Central Processing Unit) where it is processed and decoded, and eventually output to the screen and sound card. And voila, you have your movie.
RAM is also known as "Primary Memory". Comparatively, Virtual Memory (also known as Secondary Memory or Page Memory) is used in place of Primary Memory, but only if there is no Primary Memory available at the time.
Since Virtual Memory is stored on the hard drive, it is significantly slower than RAM; therefore, virtual memory usage should be avoided whenever possible. To compare: hard drive speeds are measured in Milliseconds (MS) where as RAM speeds are measured in Nanoseconds (NS). Generally speaking, the more RAM a computer has, the faster, or "more optimized" it is -- especially when switching between tasks.
If you are constantly getting the message that your system needs to increase Virtual Memory settings and you're not overworking the PC, I would suspect a memory leak. This is, of course, assuming that you haven't played with your virtual memory settings in Windows (it's best to leave it alone or restore to default).
FIX
look in Control Panel: System, Advanced, Performance, Settings, Advanced, Virtual Memory. I believe it's in a similar location in other versions of Windows.
May 11, 2009 | HP Compaq FS7600 17" CRT Monitor
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
