Question about Poulan "Poulan" Push Mower
My poulan pro lawn mower will not shut off with out pulling the spark plug wire off. when i let go of the handle, the throttle lowers, but it will not die. i have full movement of the cable and it starts and runs great
studio500
  • 36 Answers
SOURCE: I have a POULAN lawn mower that has sit unused for
Ensure that you refill it with new fresh fuel not the fuel that was left inside it as fuel does has a limited life.
Regards
Marc
Posted on Apr 17, 2009
ken_howard
  • 10 Answers
SOURCE: starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Posted on Apr 25, 2009
  • 5 Answers
SOURCE: Poulan 6.75 Lawn mower will not start
trouble shooting tips: oil is too full
fuel jet and float are plugged
spark plug lead wire may be damaged inside and needs to be replaced.
Posted on May 02, 2009
mowerman1857
  • 389 Answers
SOURCE: Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Posted on Sep 14, 2009
  • 430 Answers
SOURCE: how to change oil in poulan 500 lawn mower
First remove the spark plug wire from the spark plug. Then tilt the handles down to the ground. It helps to have something you can slide the handles under or otherwise hold them down. Underneath the mower deck there will be a drain plug. You are in front of the unit facing it the drain plug will be at about 7-o'clock a few inches from the cranckshaft. It will have a square hole in it. Use an extension on a 3/8ths drive ratchet in the square hole and remove the plug. Be careful not to cut yourself on the blade, I usually remove the blade first and sharpen it while the oil is draining. Loosening the dipstick from the tube on top will help it drain faster. When its done draining replace the plug and reinstall the blade if it was removed. Then refill from the dipstick tube. The unit will take approx. 22 ounces of oil. Do not overfill.
Posted on Jan 04, 2010
Poulan pro troubleshooting
Before we get drastic about this try pulling the spark plug out and see if it will then without the plug in it, but I need a model number to go further.
Aug 19, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
Poulan pro lawn mower. not getting fire replaced spark plug still not getting fire
sounds like a coil issue, it is a u shaped multi-layered metal item next to the flywheel when you take off the pull cord housing or a short in the spark plug wire.
Jul 21, 2014 | Garden
How do i change the spark plug on my lawn mower
Pull the wire off the spark plug and then take a 3/4 inch spark plug wrench and loosen the plug and remove it. Be sure to check the gap on the plug before putting it in, they sometimes get hit when being handle so never put one in without checking the gap first.
Jun 14, 2014 | Poulan "Poulan" Push Mower
How do I shut the engine off on an Ariens walk behind Lawn Mower?
Adjust the brake cable that leads from the handle to a full down position.
Jun 03, 2014 | Ariens Garden
Hi, Received a used poulan we940rc with broken cable (start, turtle, rabbit). Cannot start engine. Check no sparks on spark plug? Magneto dead? Any manual so I can try to repair if not will scrap. Cao...
You can check for spark by removing the spark plug, reattaching the plug wire and grounding the plug to the head and having someone pull the starter while watching the plug. The start position on the throttle cable actuates the choke on the carb, which is pretty important for a mower with a throttle cable in order to get it to start. Get the model number off the back of the mower and take it to a small engine repair parts shop.
If really helpful, please rate.
Jul 12, 2011 | Poulan "Poulan" Push Mower
I have a Poulan Pro 650 model. I need to flush the fuel line because I think the gas I put in it is bad. I no longer have the manual so I don't have any instructions. Does anyone out there have any...
First step is to take the gas cap off and tip the mower to pour the old gas out. Leave the cap off for awhile and let the rest of the gas evaporate. After you have handled this, pull out the spark plug and pull the started a few times. This will push whatever gas is left in the carb and lines into the cylinder where it can evaporate or spill out of the spark plug hole.
Jun 02, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Poulan pro 625 series Will not start. I have changed the spark plug. Tested the plug for spark (yes) Checked the primer- works , sprayed starting fluid in spark plug hole and intake -nothing. it act like...
1st: stale fuel...won't burn...regardless of spark...
2nd: watch primer when it comes back up, it must "fill" with fuel...a tiny bubble is o.k. If not, carb replacement...
3rd: Flood to hell and back...remove the plug, pull 5 or 10 times to clear the gas...dry off plug...install...hold trigger wide open, and pull..NO PRIMER
if this works, go back and review starting procedure
8^)
Apr 17, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Jun 24, 2009 | Poulan "Poulan" Push Mower
I have a poulan pro self propelled lawn mower that won't start. It ran fine this morning, but after I took a break and went back outside to finish mowing, it wouldn't start. It sounds like it won't...
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
This hapened on my mower and it turned u that the spark pug was too bigfor the motor and the valves were totally broke!!!Not good...
Jun 06, 2009 | Poulan Pro " Pro" Self Propelled Mower
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan "Poulan" Push Mower Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
