Question about Sewing Machines
DRESSMAKER 3M 852H OWNERS MANUAL
LOOKING FOR A DRESSMAKER 3M 852H OWNERS MANUAL . CAN ANYONE HELP ? THREAD KEEPS BREAKING AND I THINK I AM THREADING IT WRONG .
2 Suggested Answers
mastermaid
  • 502 Answers
SOURCE: I need a manual for Dressmaker 3M 852H machine.
You can get that here, just send them a request.
Posted on Aug 26, 2011
jaedj
I have a 3m - 952H, is this an upgrade of the 852. If yes, is there a manual for it?
Posted on Feb 08, 2014
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Where can I download a free manual for a Dressmaker Deluxe Zig Zag sewing machine SWA 2000
Try searching the internet for:
Manufacturer + Model + the word "Manual"
Perhaps this will help:
Dressmaker 2000 Sewing Machine Threading Diagram
Dec 19, 2015 | Sewing Machines
To Whom It May Concern, I have a B &E Enterprises Dressmaker Sewing Machine Model 3 M - 852. I do not have the user manual. I need the user manual. Do you have a copy of the user manual for this sewing...
I was unable to find the manufacturer's website. They will usually provide you a free PDF copy. As an alternative, I did find a site that you can purchase a copy.
https://www.tradebit.com/filedetail.php/146678614-dressmaker-3m-852h-owners-manual
Jan 04, 2015 | Sewing Machines
Free manuel for Dressmaker sewing machine model S2402
If this offer is still good i desperately need a 2402 manual !! thank you so much
Victoria
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Aug 19, 2012 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Top thread keeps breaking
Check your threading path with your manual. If, you look up your manual online at brother.com it can be made larger and you may spot your mistake easier.
Jul 20, 2010 | Brother XL-5130 Mechanical Sewing Machine
Dec 07, 2009 | Sewing Machines
Sewing Machines Logo
419 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
