Can't get pass the blackscreen password - Computers & Internet
  • 928 Answers
That is the BIOS password
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop. Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time. Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system
Posted on Aug 15, 2008
Circircuit diagram for led driver board led blinking on D4 lg tv 55le5400 no picture blackscreen
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 22, 2016 | LG Televison & Video
Tip
My laptop shows blackscreen so i reformat it and now its not anymore showing the...
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 15, 2010 | Computers & Internet
Why mysql blackscreen dissapear when press enter button
this is normal for mysql server. It's simply wanting you to set the administrator password. the black box appears, you type your password, the black box closes.
This means the password is now set to what you typed in the black box (command prompt box)
Aug 07, 2014 | Microsoft Windows 7 Ultimate for PC
Displays blackscreen with message saying bootguard
sounds like it needs a password problably in the bios or someone put a password on the drive what operating system ? try if you can pluging hard drive into another pc or laptop see if you can access it that way ?
Mar 15, 2013 | Dell Studio 17 Laptop
How to clear blackscreen for windows 7 before login
Hello there anvesh_t416 if i got it right you have a blackscreen of "death" if you can get into safe mode, Navigate to the Start -> All Programs -> Accessories -> System Tools program group then click on system restore and see if it gets to a point that this stops. If you cant do that then your only option is to format your pc...
Mar 12, 2013 | Computers & Internet
Blackscreen on start.no display
Try the extension RGB monitor socket on a monitor to see if that works. If it does you might have hit the function key to switch the display to externel. Look in your manual about switching displays this will help you.
It will be something like <function F4 or something similar.
Dec 31, 2012 | HP Pavilion dv2000t Notebook
Lap top goes to a black screen after user password is entered
is there anything at all on the screen, or just LEDs are on but screen is still black?
it may be:
1 backlight of the screen,
2 video card
3 motherboard
anyway in all of those cases you need to go to some technician if you are not familiar with dissembly of the laptop.
Mar 13, 2009 | Toshiba Satellite A215-S5822 Laptop
Default bios password toshiba satellite a135-s2276
the best thing is to do the system recovery process ..
Aug 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Did you get this from another person or business?
Either way there's a way to get rid of it.
Let me know
comier957
Aug 08, 2008 | Toshiba Satellite A135-S4527 Notebook
Computers & Internet Logo
373 people viewed this question
David Payne
David Payne
