Question about Toshiba 19HLV87 19 in. LCD HDTV
I smelled a burning electrical odor and saw smoke coming from the top right rear of the TV. Is a 4 yr old TV catching fire a replacable item or is it repairable?
  • 36 Answers
Posted on May 21, 2011
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
Why is there smoke?
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Aug 23, 2012 | Toshiba REGZA 37RV530 LCD TV
I have a 1990s JVC tv that we were wattching the other day then we smelled a smoky smell. Then horizontal lines and staticy sound started to go through the tv. We tried canned air to clean the vents a few...
That tv is very close to catching on fire. UNPLUG IMMEDIATELY. When electronic equipment is old they dont just stop working sometimes. Sometimes the electrical current starts burning the wires and the dust inside. there is a definare odor to electronics burning or shorting out. smell around the air vents in the back of the TV. youll know if wires were burning its a distinct odor
Jun 03, 2012 | JVC Televison & Video
KS850 circular saw 'burning' & smoking
The brushes in the electric motor have failed..
And sounds like bearing are shot too..
The motor is shot..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 01, 2009 | Saws
2005 Chevy Impala exhaust smell
neither one of these would cause gas to leak. sure it is not coolant ? if you think it is gas it is not safe to drive car as it could catch on fire. possible cause would be a leaking injector.
Jan 27, 2009 | 2005 Chevrolet Impala
Kenmore ultra self cleaning oven or top heat
I found that the 220 plug had burned out, that was where the smoke came from. The display worked because the ground "prong" was the only one burned. Had to replace the electrical 220 socked and the electrical plug on the oven.
Jan 13, 2009 | Ovens
Burning smell from AC Unit
http://www.hannabery.com/faq14.shtml
"Odor problems can be as serious as a gas leak or as simple as a dirty air filter. But remember, a good mechanic doesn't just use his hands. He uses his ears and nose. Unusual odors could indicate a serious problem and should not be ignored.
We will go through each of the five categories and list the possible causes and things to check.
1. Electrical odor - Electrical odors are usually caused by parts overheating. Indoor blower motors are a common example. If there is a mechanical failure such as the bearings seizing up, the motor over-heats and the insulation on the wires and the motor windings themselves start to melt, causing the odor.
Sometimes loose electrical connections cause wires or plastic relays to overheat causing electrical odors.
It is possible for a very dirty air filter to cause the odor. If the airflow is restricted enough, it could cause electric resistance heaters to overheat, even burn-out.
If you smell an electrical odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
2. Burning odor - This is similar to an electrical odor only worse. It is also sometimes accompanied by smoke. Once again, this can be caused by parts or wiring burning-up.
It can also be debri such as plastic getting into the ductwork and melting on the electric resistance heaters or heat exchanger.
If you smell a burning odor, check your air filter. If it is not blocked, shut off equipment at the breaker if possible and call for service.
3. Gas odor - First of all, if you really smell gas and suspect a gas leak, you should open the windows, get out of the house, then call the gas company.
Now excluding that "worse-case" scenario, if you notice an odor that smells like gas and it seems to be coming out of the supply vents, it usually isn't gas. Sometimes dust that settles on the heat exchanger during the summer months burns off at the beginning of each heating season and it smell just like gas.
If the odor doesn't seem to be coming from the vents, try to pinpoint where the smell is coming from. Use your nose. If it is gas, it usually would be from a leak in a pipe fitting or at the equipment itself.
Gas odor is the one that causes the most fear. People think of gas explosions or carbon-monoxide poisoning. Well, gas explosions are very rare and carbon-monoxide for the most part is odorless.
Having said that though, don't take a gas odor lightly. If you can't locate the source of the odor and you are worried you have a gas leak, remember, open the windows, get out of the house, then call the gas company.
4. Oil odor - Oil odors are usually caused by one of two things. An oil leak/drip or an oil burner that is not working properly.
The oil leak is usually easy to spot. Just look for oil. Check the burner itself, the oil tank, filter and oil line. Sometimes it is just a matter of tightening a fitting. If there are no signs of an oil leak then it is most likely a burner problem.
This can be caused by many things, too many to list. It could be a minor adjustment to the burner to a faulty or blocked chimney. From a bad fuel pump to a plugged oil nozzle. Listen for any unusual rumbling or banging sounds or smoke or soot while the burner is running. If you notice any of these things and/or you have an oil odor, you should call for service immediately.
One other common problem today is that new houses are insulated so well and are built so tight that they run out of combustion air, causing odor problems. In this case it is just a matter of bringing in a fresh air for the burner. Call your local Heating Company to assist in a proper diagnosis.
5. Damp and musty odor - This is more common in the air conditioning mode. Sometimes attic units or very damp basements have this problem. Check for air leaks in the return ducts. Check for water damage to the ducts or air handler itself. Possibly consider having your ducts cleaned. Run a dehumidifier and see if the odor goes away.
But this odor problem is almost never due to a problem with your equipment.
Final Tips:
Keep in mind that almost all heating systems cause an odor the first time they are fired-up. And the first few times at the beginning of each heating season. Brand new furnaces are coated with oil to keep the heat exchangers from rusting. This burns off, creating a bad odor - even smoke. But it usually only lasts for about 20 minutes. Opening the windows usually solves the problem. And the first few times the backup heat on a heat pump kicks on, it smells like an electrical smell. This might last for a few days but isn't that bad. If you are worried, call for service.
Remember to check for a clean air filter and that your vents are opened. Check to see if the fan is working which mean your motor hasn't burned-up.
Check for air leaks in damp areas, oil stains or rumbling sounds, strong gas odors - these all indicate problems. Do not ignore them.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered."
Jul 28, 2008 | Sharp CV-P09FX Air Conditioner
My monitor is still working but has an odor coming out of the vent holes of back cover. This is a Fuji 19" LCD Monitor (Model: FP-988D) abut 2 years old. All features still seem to work but I have...
It is normal for computer monitors to run hot and smell out
of the vent holes. The question is how much and how bad.
Under-sized power resistors on the circuit board often smell
like burned toast, this is normal. If the smell is very irritating
and "aromatic" like burned varnish, however, causing your nose
or eyes to burn, than the cause is probably due to an overheated
transformer and failure will occur eventually (soon)
(Transformers are made of a spool of wire, insulated with
Varnish. When overloaded or shorted inside, they stink)
If you see smoke, stop using it. Otherwise you have nothing
to loose, since nobody fixes monitors anyway, but keep an
eye on it to make sure it does not cause a fire. Always plug
your monitors into a power bar with its own fuse or breaker.
Finally if the monitor does to catch on fire, the more the
merrier, since most dealers and manufactures are much
more likely to give you a new one, when you rave and rant
about a lawsuit for almost burning your house down.
The best time to get warranty is during a sale on Saturday
afternoon !!!
More realistically, if the monitor does catch on fire, shut off
the power bar, real fast. Then unplug it and throw it in the
Bathtub :)
Martin
May 25, 2008 | Computers & Internet
Turns on then right off after a click saw smoke coming out of tv
check the board, maybe is burned , I have the schematics, if you want it, write me to ipbass@gmail.com, only I need the model of the board
Mar 03, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Toshiba 19HLV87 19 in. LCD HDTV Logo
314 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
