Question about Garden
12 VOLT ELECTRIC WINCH, MODEL # 2Z894. Cable cannot be pulled out in free wheeling mode.
2 Suggested Answers
phillipstech
SOURCE: can not pull winch cable out had to take cover off
The clutch knob on the side needs to be loosened up. Rotate this and the shaft will be free to pull the cable out.
Posted on Dec 27, 2009
Electric winch
Is there a load switch on winch
Jul 13, 2012 | Electric Superwinch 12 Volt DC Winch -...
Wire a winch
The 1585202 winch is capable of pulling 8500 pounds when provided adequate DC power. With no load (winding up slack the cable) the motor requires 84 amps and winds at 18 feet / second. When fully loaded (8500 pounds), the motor requires in excess of 320 amps and winds at 3.5 feet / second. That's an awfully large amount of current and it will need heavy duty power supply cables to work without overheating or melting insulation. I suspect your 1585200 is the same model with same electrical requirements, but did not include a fairlead, mounting plate, etc..
Superwinch has wiring kit #2007 for front mount (5 foot cables) and #2008 for trailer mounts (25 foot cables) and can simplify the installation with other accessories as well. They're a U.S. company and can be contacted them directly:
Superwinch, LLC
359 Lake Road
Dayville, CT 06241 US
Ph: 860-928-7787
F: 860-928-1143
www.superwinch.com
Dec 22, 2011 | Electric Superwinch 12 Volt DC Winch -...
I have a 14 volt source but when I try the winch in either forward or reverse the voltage drops to 4 volts. The drum is not seized because you can pull the cable out easily by hand.
Not only do you need a 12 volt supply (13.8V) to operate this winch, but you also need a.) wire large enough to carry the electrical load, and b.) a power source that has the necessary current (amps) to turn the motor.
If you have wires that are too small, they will heat up and not be able to deliver the current (amps) required by the motor. If your power source is to small - it can not supply the current required. The result of either conditions is "voltage drop". This can be explained the same way your car needs a 12 volt car battery to start. If that car battery was dead, you couldn't connect eight "D" cell batteries (8 x 1.5volts = 12 volts) together and attach to the car's battery cables and expect it to start. This is because the amount of current available in the car battery is hundreds of time greater than eight "D" cell batteries - even though when the D cells are connected in series - both systems deliver 12 volts.
If neither of the above conditions is present, then there could be an electrical problem with the drive motor itself. This could be a shorted / melted winding or other electrical connection that is not right, even if the drum spins freely.
Apr 04, 2011 | Electric Superwinch LP8500 Series Utility...
When I try and use the winch all I get is a clicking sound from the control box. The winch motor will not engage in or out. When the winch clutch is placed in the out position I can free spool the cable...
It sounds like you have broken a pinion tooth. Remove the screw from the end housings and open to inspect the drive gears. Parts can be purchased from Superwinch for these or off e-Bay.
Jan 16, 2011 | Electric Superwinch LP8500 Series Utility...
I can not get my cable out of my winch, I hear only one sound on top when I activate the command, but the engine does not. Here the temperature is about -15 celsius.do you think that the cold can freeze...
may have ice in gears or check power connections and switch may have gone bad--radical approach take a torch low flame and warm the drum and cable not trying to get red hot just to warm up drum if ice in gears will thaw
Dec 10, 2009 | Electric Superwinch 12 Volt DC Winch -...
Can not pull winch cable out had to take cover off
Nov 10, 2009 | Master Lock 5400d: Portable Select Access...
Wiring up super winch
I am wiring a Superwinch 4500 to my Yamaha Rhino.
Problem the two red wires go to the key switch.
Do they just splice into the 12 wire ?
Sep 25, 2009 | Electric Superwinch LP8500 Series Utility...
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Sep 08, 2009 | Heavy Duty Associated Equipment 6002B...
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
