Question about Pool & Spa
BAD PUMP SEAL - Pool & Spa
  • 1,383 Answers
WOW THATS WAY TOO MUCH INFO .. DO ME A FAVOR, FIND OUT WHAT KIND OF PUMP YOU HAVE .. LOOK THREW EBAY AT THE PICTURES, THATS A START... THEN SEARCH FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. NOW YOU ARE INFORMED AND HE WILL BE GLAD TO HELP YOU.. REMEMBER TO PRIME THAT PUMP !! jay
Posted on May 26, 2011
Is the pump seal bad when doesn't spray /pump well?
The sign of bad seals are water leaking out of the bottom of the pump. The high pressure seals get bad enough the low pressure oil seals will fail as well and water will get into the crankcase.
Weak or fluctuating pressure is a sign of a problem with your check valves or seal problems with your unloader valve.
Jun 11, 2014 | Craftsman 2500 PSI Briggs Stratton...
Front pump seal and pupm bushing
to change front pump seal and bushing you have to remove the transmission and remove the pump for disassembly for the bushing. you are very near a overhaul
look in oil pan for metal dust or piece of metal, brass
Oct 15, 2013 | Chevrolet 1500 Cars & Trucks
Is 1984 chevy caprice water pump top hole stay open
pump seal is bad, if you tap a bolt into it and thread seal it you may ger 20,000 more miles. the seal is bad the pump may be fine
Sep 04, 2012 | 1988 Chevrolet Caprice
Coolant leaking from underneath pump
Pinpoint the leak if its coming out of the pump you have a bad seal or pump bearing and the pump must be replaced. Hope this helps.
Sep 07, 2011 | 1997 Chevrolet K1500
Water leaking beyween the empellarand moter housing
pool pump repair guy in longwood florida , here to save the day.. Ok what you have is a bad shaft seal (90% of the time) OR tank crack or a cracked seal plate or a bad gasket or o-ring.. look at the link and it wil help you ID your pump and take it apart. prim that pump after a repair !!! www.poolmotorrepair.com/
the cost of a shaft seal
Jan 15, 2011 | A.O. Smith SQ1102 Pool Pump Motor
A dripping water pump
Your seal has gone bad on the pump. Your best bet is to remove the pump and replace the seal and the pump. This will fix your problem. You have to replace the pump because if you just do the seal the old pump will not handle the presure and fail. Then you will have to do the work all over and replace the seal and the pump. Just do it all in one shot.
Dec 13, 2010 | 1997 Chevrolet Cavalier
Replaced my boost pump and now eveb before I turn on bust pump water runs out around metal seal and seal bracket. I have removed and reseated seal and applied sealant lub. any ideas
You either have a bad seal or bad connector..make sure you check them both very well....and if you didnt use a new seal, the old seals are pron to leak when re used.
Feb 03, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
43 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
