Question about Plumbing
Pump was replaced with new control box, pressure switch, and burns up capacitors after 10 min oper max. Have replaced repeatedly still same problem-no right answer yet Control box that came w/pump keeps tripping reset immediately upon applying power
    President:
  • 1,378 Answers
I'd start with verifying the voltage present matches the voltages the motor and control box are set to receive. Capacitors blow due to being energized too long or having to much current pass thru them. Voltage issues could easily explain all the symptoms you have described.
Posted on May 21, 2011
Problem code c1440on 2003 ford explorer
C1440 Pressure Transducer Input Circuit Failure YES
C1440 (ABS only) Pressure Transducer Input Circuit Failure ABS Module Go To Pinpoint Test P .
Normal Operation The brake pressure switch provides an additional speed control deactivation if the brake pedal position (BPP) switch fails. When the brake pedal is pressed, 1700 kPa (246 psi) of brake fluid pressure in the brake master cylinder opens the brake pressure switch, removing B+ voltage to the speed control servo electric clutch.
    Possible Causes
  • circuit 10 (LG) open
  • circuit 307 (BK/YE) open, short to power
  • ABS module
  • brake pressure switch
  • speed control deactivator switch
PINPOINT TEST P: DTC C1440 (ABS ONLY) - PRESSURE TRANSDUCER SIGNAL FAULT CAUTION: Use the flex probe kit for all test connections to prevent damage to the wiring terminals. Do not use standard multimeter probes.
Test Step Result / Action to Take P1 VERIFY THE DTC
  • Connect the diagnostic tool.
  • Key in ON position.
  • Clear DTC C1440. Road test the vehicle. Repeat the self-test.
  • Does DTC C1440 repeat?
Yes
GO to P2 .
No
The system is OK at this time. P2 MONITOR THE BRAKE PRESSURE SWITCH PID FOR CLOSED POSITION
  • Enter the following diagnostic mode on the diagnostic tool: ABS Module PID.
  • Monitor the powertrain control module (PCM) brake pressure switch PID.
  • With foot off the brake pedal, does the PID read closed?
Yes
GO to P3 .
No
GO to P4 . P3 MONITOR THE BRAKE PRESSURE SWITCH PID FOR OPEN POSITION
  • Monitor the PCM brake pressure switch PID.
  • While pressing the brake pedal, does the PID read open?
Yes
GO to P9
No
GO to P7 . P4 CHECK THE CIRCUIT 10 (LG/RD) FOR AN OPEN
  • Key in OFF position.
  • Disconnect: Speed Control Deactivator Switch C1025.
  • Measure the voltage between the brake pressure switch C1025-2, circuit 10 (LG/RD), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to P5 .
No
REPAIR the circuit. CLEAR the DTCs and REPEAT the self-test. P5 CHECK THE BRAKE PRESSURE SWITCH
  • Measure the resistance across the brake pressure switch pins, component side.
  • Is the resistance less than 5 ohms?
Yes
GO to P6 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P6 CHECK CIRCUIT 307 (BK/YE) FOR AN OPEN
  • Connect: Speed Control Deactivator Switch C1025.
  • Disconnect: ABS Module C155.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE). harness side and ground.
Yes
GO to P9
No
REPAIR the circuit. CLEAR the DTCs. REPEAT the self-test. P7 CHECK CIRCUIT 307 (BK/YE) FOR A SHORT TO POWER
  • Disconnect: Brake Pressure Switch C1025.
  • Measure the voltage between the ABS module C155-40, circuit 307 (BK/YE), harness side and ground.
  • Is any voltage present?
Yes
No
GO to P8 . P8 CHECK BRAKE PRESSURE SWITCH
  • Start the engine.
  • Measure the resistance between the brake pressure switch C1025 pin 1, component side and the brake pressure switch C1025 pin 2, component side while firmly pressing the brake pedal.
  • Is the resistance greater than 10,000 ohms?
Yes
GO to P9 .
No
INSTALL a new speed control deactivator switch. REFER to Section 310-03 . CLEAR the DTCs. REPEAT the self-test. P9 CHECK FOR CORRECT ABS MODULE OPERATION
  • Disconnect all ABS connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all ABS connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. TEST the system for normal operation.
No
The system is operating correctly at this time. Concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
Jul 01, 2017 | Ford Cars & Trucks
I have a utilitech 1/2 hp pump. I runs 5 min., and then stops. If I let is sit for 10 min. and then replug it will run another 5 min. then stop. I have taken off the bottom and cleaned it. What now?
It appears to be over loading and being shut off by the thermal overload switch. This can be from failing bearings, overload as the motor is too small for the job, the rpms are too low for correct operation and the start capacitor is not being taken out of the circuit on starting. ( some small hp motors have a set of contacts at one end that are closed when stationary but on reaching operational speed are opened by a centrifugal bob weight. When closed the start capacitor induces extra voltage to get the motor turning and when running is taken out of the circuit. The points in this system are known to burn together and so keep the capacitor in service which will over heat or burn out the motor. Best have it checked out by an accredited electrical motor re-builder for the cause of the problem.
Nov 13, 2014 | Cars & Trucks
DAB Jet 62 won't pump
U might've burned the start capacitor also. If u don't see one on the exterior,check inside the end bell (cap) of your motor. Do u hear the motor hum? If not there a likelyness u burned ur motor
May 26, 2017 | Plumbing
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
Aug 17, 2011 | 1993 Mitsubishi Mighty Max
No we are on a well system and there is no way it could have been frozen. i was trying to turn up the hot water tank. then put the timer on full time pumping and now no water.
OK. Water well.
1) Let's do a punch list for deep well:
Check 20 amp 240volt circuit breaker to well. Click breaker all the way one direction and then back other direction.
Look at pressure gauge on well to see if pressure is zero.
Open pressure switch cover (small grey box about size of baseball) and see if points are stuck.
Points can burn together sometimes.
Turn off power to well, separate points and use fingernail file to clean points.
Also check if pressure switch is getting 240V. Move wires to another same-size circuit breaker to see if breaker is functioning correctly.
If pressure at tank is zero, then solinoid could be bad in control box, or motor could be burned out.
-Buy new control box at hardware store for $60 and replace.
-Call water well company to replace pump.
2) I am not 100% familiar with shallow well operation to give you detailed information.
Feb 14, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
MQ3-45B problem.
have you opened the electrical cover? four screws on top. Is there water inside?
Mine has stopped working also and has water in the elect. box. I'm pretty sure from condensation. The water coming into the pump is really cold and the warm motor is causing condensation which finally builds up and shorts out the capacitor. Although my capacitor looks ok, but the little controller on the circuit board is melted. Would like to try and find a new circuit board, don't know where to look as yet.
Jan 10, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Drain problem
Could be a pressure switch problem. If the switch doesn't know it's empty, it will keep trying to pump. Remove top and locate switch. There's a small hose going to it. Remove the switch and blow in it see if you hear a "click". Also blow through the hose and you should hear bubbles or clear air into the tub. Put switch back on and try again. If no sucess, repl. pressure switch.
Apr 09, 2009 | Kenmore 43142 Front Load Washer
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Plumbing Logo
85 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
