Question about Arctic Pool & Spa
I change the #1 motor and change my control pannel. When i turn my braker on the # 1 motor runs for 10 sec. and starts to hum [no water moving].the control pannel lights up but there is a blank screen. I can press all the bottons but thay do not work.
  • danchris May 22, 2011
    Hi MARK, the motor is new and the control panel as well. When I turn the power on, the panel lights up but the screen is blank. When I push the bottons on the control panel nothing works
    Dan
  • 776 Answers
Your motor may have siezed (frozen) and not turning at all. The humming you hear is likely just the 60 Hertz AC from your outlet - you can hear it because it is trying to turn your fozen motor and you hear the pulsing of the line voltage.
Depending on how handy you are, you can either call an electrician or try fixing it yourself.
First, if you can access the motor and see the shaft, try putting some oil on the bearings. Use something like "3 & 1" oil, sewing machine oil, or even motor oil. Let it sit over night and try it again. If it spins, great. If it doesn't, you will need more help than I can provide in an e-mail.
Good luck.
-Mark
Posted on May 21, 2011
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
FRS26R4AB5
did you change the ptc overload/ relay on the side of the compressor,the capacitor is in parallel with the start/run windings and the compressor will run without this part,but not with a bad ptc
Aug 30, 2012 | Frigidaire Refrigerators
Am trying to open pool, motor hums but will not run
Sounds like COULD BE something (a small stone or twig) jammed in the impeller. See if you can spin it using a long screwdriver, if it moves, it is not jammed. If it spins, I hate to say it might be the motor is gone.
May 23, 2010 | Sta Rite StaRite Duraglas Inground Pool...
After 10 sec. After start up the tv starts to make a large growling sound for about 5 secs. Then repeats every 15 sec. Sounds like if might be a fan. How many fans in this t.v. . Took the back cover off...
there's 3 fans. 1 by the video board. 1 in the middle of the set infront of the heatsink and 1 behind the lamp. make sure all 3 fans are running and put your ears by them to check. if all of them are running the sound might be coming from your colorwheel. If it sounds like a loud whinning/humming or buzzing noise then more then likely its your colorwheel. Let me know what you find and please rate me. Thanks
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 33 gallon craftsman compressor model #919.167330. If the air is totally out of the compressor and you plug it in, it will build to full pressure and then turn off normally. When you begin to use...
i think you will find there is nothing wrong with the compressor part of this its all down to a faulty motor
if it cant start up the motor the motor will hum at first then the circuit braker pops out? yes???
check your getting full mains power first as if its trying to run on a very long extenshion lead its not getting the full power to start up, and you will need a much heaver lead,,,if its in a plug on the wall, change the capasitor on the motor,,,this is the part that hold a lot of volts to kick start the motor over when it first trys to start,,if this capasitor has droped in holding its charge there wont be enough volts in it to kick start the motor over,,so the motor starts to hum first trying to start but it dont stand a chance of spinning up
so it keeps pulling more and more amps till the braker pops out,,,watch this capasitor it can realy bite you if you tuch the two ends that are live????
the motor has two windings in it,,a start up winding and a running winding,, if its been humming for some time now it could have damaged the start up winding
Mar 28, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Nov 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Ie error code
The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound
Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
GE dishwasher won't start
You have a washer control board problem or a burnt connector or both.
Mar 17, 2017 | GE 24 in. Profile PDW9200J Built-in...
Pool & Spa Logo
53 people viewed this question
Top Arctic Pool & Spa Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
Bill Jordan
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
