Question about GE Monogram® ZISS420DMSS Side by Side Refrigerator
Zisb48dyb is collecting ice on left wall of freezer below ice maker
  • 3 more comments
  • boblbarth May 21, 2011
    I have turned off water and will see what happens. If it is the defrost cycle, what is happening to allow water to come down left side and then freeze?
    Helpmech,
    I do not understand what you wrote about the defrost. Can you try to explain it more clearly: where does the ice collect and why is this different from normal operation, why does it melt to form water and why does this water run down left side and refreeze? thank you
  • boblbarth Jun 05, 2011
    there was no waater/ice forming with the water off. After I turned it back on, the icemaker worked until about half full and the ice returned starting above the icemaker down the left wall. I have shut the water again. How do I find an icemaker/line leak? thank you
    there was no water/ice forming with the water off. After I turned it back on, the icemaker worked until about half full and the ice returned starting above the icemaker down the left wall. I have shut the water again. How do I find an icemaker/line leak? thank you
  • boblbarth Jun 06, 2011
    the water is starting from the TOP of the freezer wall--above the ice maker. Can this still be from ice maker. It didn't happen when water supply was turned off. Is there a water line above the freezer?
  • GE Master
  • 5,370 Answers
It can be two possibilities
1) the ice maker is leaking water and that water is accumulating in the freezer section.
2) The other possibility is there is defrost problem.
If the ice is getting collected due to water leaking from ice maker then, to confirm this problem, just turn off water supply to the ice maker and water dispenser.Its just the valve to turn off and on.
The valve is at the back side of refrigerator.Just turn off that valve and then check after 24 hours.Is the ice still getting collected or not.If it stops getting accumulated then ice maker is leaking.Remove the ice maker and inspect the leak.But with water turned off, still ice is accumulating, then its defrost problem.
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.
The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Posted on May 21, 2011
  • 2 more comments
  • raj somaiya May 21, 2011
    If the problem is due to defrost then its due to freezer section getting over cool as defrost is blocked and ice getting collected on the evaporator coils.This ice is melting water and getting collected on the freezer wall.The evaporator in the inner side of freezer section.The defrost thermostat and defrost heater both located beside on the evaporator coil.-----------
    If turning off the water is not helping to resolve this problem, then get the manual defrost procedure done first of all. This will melt all ice from everywhere in the freezer/ fridge sections.-----
    This should help.Thanks.Helpmech.
    There is evaporator coil in the freezer section.When the coils gets frosted, after that defrost cycle starts.But if the coil gets over frosted and after that defrost cycle starts that means defrost cycle is running, but its running bit late.
    Now why defrost cycle is running late? this has many reasons like defrost heater got weak, defrost thermostat not working or defrost board got weak.But in defrost cycle all ice melts and drains into drain pan above the compressor.---- but if when defrost cycle is running and in between the cooling cycle again starts then the water gets frosted where it is and slowly --- slowly ice gets accumulated in the freezer wall section .You notice it when too much of ice gets accumulated, but it slowly --- slowly gets accumulated.---------- But once you try manual defrost procedure this will be confirmed, that its defrost related or heater related or thermostat related.,But if defrost reset procedure solves this ice accumulation problem, then it was board related and board got reset and this solved your problem.-------------
    So this will help.Thanks.Helpmech.
  • raj somaiya Jun 06, 2011
    you will need to remove ice-maker out and inspect for any crack or you will have to again try the same procedure.Like turn water off to the unit then after few hours again turn on then after few minutes you will have to notice and check for leak below the ice maker section.You will have to inspect by keeping the door open.When the door gets closed one switch gets pressed.You will have to press that door switch closing button manually with your hand, so the system will run like it is running, then see below the ice maker, after some time you will notice water leak.But this will be sometime time consuming.How much you will wait to locate leak.------- But other possibility is good.Remove ice maker out of the unit, then pass water and fill water in the ice maker chamber, then see water will leak from its low side.Where the water leaks, seal it with water/plastic sealant and then see.You can get this sealant from home depot or wallmart stores.But if its still leaking then ice maker assembly needs to be replaced and this will solve the issue.--------
    Yes there is water dispenser line.It can be leaking or the line is got cracked.Has to be inspected.------
    Thanks.Helpmech.
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
GS 5 sha. How do I remove icemaker?
Usually ice makers are held in by two screws on top of the ice makers if mounted to the left hand freezer wall. Sometimes there is a third ***** under the ice maker at the side wall. A more complete model number would be helpful.
Nov 20, 2015 | Whirlpool Refrigerators
Ice in freezer and warm refrigerator Zisb48dyb
If I remember correctly, GE had a issue with the drain pan as it would clog or restrict and back up in the freezer and in the air return (hence, water under crispers if refer section). GE has a repair kit for this and they have also changed the drain hose to prevent self restricting as it leaves the freezer. This part is an Icing kit part# WR49x10021, this comes with complete instruction as to what your changing and why. This should solve your drain and water problem, if this is what your issue is. I hope this was helpful.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 31, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
My Whirlpool refridgerator has water in it. Where could it be coming from and how do I fix it.
Water must be getting melting from freezer section/.See if over ice is getting collected in freezer vents and freezer walls.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 21, 2012 | Whirlpool Refrigerators
Refrigerator is producing water which seems to drip down from the top rear center of refrigerator which is below the freezer. The amount is 1 or 2 cups per day and it collects below the bins at bottom of...
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator has a bulge on the outside of the cabinet on left side where the ice maked is located and that side of the box is cold and sweating
Empty the ice from the ice maker. It sounds like you have a build-up of ice between the ice maker and freezer wall. When you thaw this ice, the bulge should go away. You may need to temporarily move the ice maker for a few hours while the freezer thaws.
Feb 05, 2010 | LG Refrigerators
Water on floor of refrigator. Our refrigator is a Frigidaire Crown series model no. F44Q18CC. We have never had the ice maker hooked up sence we owned our refrigator.We bought it about 5 years ago. Lately...
Water collects INSIDE the refrigerator ? It is coming from the freezer. You have a plugged up defrost drain - look for a drain cup inside your refrigerator section agains the wall, this leads to a plastic tube that connects through the back wall of your refrigerator down a drain tube - see if you can remove this and with an object pass it through the drain tube to dislodge anything obstructing the water passage - if you do not have a drain cup in refrigerator then look in your freezer behind the panel you should see a drain hole below the evap fan, where the ice melts and drains through the tube - if this area is iced up or blocked water will overflow to your refrigerator through the cooling vents :)
Sep 18, 2009 | Frigidaire Refrigerators
Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
GE Ice Maker that leaks water down the freezer wall
Ice makers have limit switches, thermal temp sensors, heating element and if anything gits out of order with these parts they will begin to do strange things like that. Now if you would like to remove it and have a look at the internal parts you may find the problem. They are a little easy to loose parts so be careful if that's your choice. A series of about six different cycles happen when they fill until the time it empties and begins again. They may cost less if you don't see what wrong to purchase a new ice maker. If you would like more help feel free to ask, Thanks, Sea Breeze
Apr 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Monogram® ZISS420DMSS Side by Side Refrigerator Logo
156 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
