Question about Akai MPC-4000 Plus Production Center (w/80 GB Hard Drive&Onboard Sounds)
I have no sound from my MPC 4000 while in main mode, after i load with sounds i can only hear them if i switch to sample mode or if i am auditioning the sound from the load screen. if i want to record a track i only hear what was recorded by switching to sample mode. this problem is driving me nuts. what is wrong with my machine this just start happening
  • 2 more comments
  • nappybutbald May 21, 2011
    Yea can do that but I need to hear what I am playing in main
    Mode screen for recording or even just playing period how do I get my sounds back it just started last week no sound
  • nappybutbald May 23, 2011
    my software is up to date with the latest edition. do you think i might need to have it serviced?
    I have no sound from my MPC 4000 while in main mode, after i load with sounds i can only hear them if i switch to sample mode or if i am auditioning the sound from the load screen. if i want to record a track i only hear what was recorded by switching to sample mode. this problem is driving me nuts. what is wrong with my machine this just start happening. My MPC is not connected to any computer, I am using headphones.
  • nappybutbald May 25, 2011
    after all this it was my settings, my son has be in my recording studio doing his thing and did not tell me he was trying to learn what his old man does cant get mad just asked him to tell me when something goes wrong after all i was 10 once upon a time. LOL
    Guru:
  • 868 Answers
Hi nappybutbald,
I see that you are epxeriencing issues with you Akai MPC-4000 Plus Machine.
Basing from what you mentioned on what is happening it shows that you maybe experincing issues related to the setting or the compatibility of your software.
You just may need to changes some setting or probably update you software.
Check the link to see updates for your Akai - http://www.akaipro.com/mpc4000
I hope that this helps regarding your concern.
Have a nice day,
mvincentc
Posted on May 21, 2011
    Guru:
  • 1,833 Answers
You should be able to audition sounds off the drive out of the stereo outs regardless of your multi settings, and also try the midi button.
I have no sound from my MPC 4000 while in main mode, after i load with sounds i can only hear them if i switch to sample mode or if i am auditioning the sound from the load screen. if i want to record a...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 23, 2011 | Akai MPC-4000 Plus Production Center (w/80...
I can't hear any sounds in my mpc 4000
Have you loaded sounds for the pads from an internal or external storage device? (Such as CD or Internal Hard Drive, if installed) - each time you turn on the power, the programs are cleared so the pads will not make any noise until you load the sounds you want.
Otherwise, it could be related to your speaker setup?
Provide some details on your system setup and whether you are loading programs etc.
Nov 07, 2010 | Akai MPC-4000 Plus Production Center (w/80...
Hi, I have an mpc 4000 and somehow I can't get it to play my samples in the main sequence mode. I recorded some drumsamples and I can hear them in the program. I can record a beat but it will only sound...
Hi - I thought this solution I read earlier may help you out - it was originally posted for another problem:
http://www.fixya.com/support/t519740-akai_mpc_4000_plus
You could set the sample to "one shot" in the trim page or in the Program>KG Mix>Zone page.... it is currently set to "as sample"... i like to use the release to let the sample fade out as long as i like... its a lot diffrent from the old poly mono thing but i like it better overall... hope this is helpfull.
Sep 24, 2010 | Akai MPC-4000 Plus Production Center (w/80...
When I try to load a program on the mpc 4000, the program won't show up on the main screen seq window. What's could be wrong? Thanks Dame
I have same problem, havent figure iyt out yet since 2month ago when i got my mpc4000. Can anybody help please mail martinwolfx@hotmail.com Cheers /Martin in Sweden
Sep 18, 2010 | Akai MPC-4000 Plus Production Center (w/80...
I insert my falsh drive into my mpc 1000 and i
First you must configure your PC to read your mpc 100
flush card. Just insert the software CD driver of your mpc
100 flush card, if you have the CD. Otherwise, you must
have a download from the internet for the software driver.
Nov 08, 2009 | Akai MPC-4000 Plus Production Center (w/80...
How can the MPC 500 play the Samples on the Pads in real time?
You have to go to the sample edit page and move the start point to the beginning of the wave sample. Right now your start point is before the sample actually starts.
Oct 07, 2009 | Akai MPC-4000 Plus Production Center (w/80...
Akai MPC 4000 Plus
Apr 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Akai mpc 4000
Dear fixya thank you for replaying to my e-mail about my mpc 4000 problem, and yes after pulling my hair out and further investigation i did fix the problem. i had no audio comming from one of the main outputs and all i did was change that one faulty audio cable and everything was all good. I took the no good cable, tied it in to a knot and dumped it right into the trash can. Now im back to master beatz...
Feb 16, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Help
When youre in LOAD or DISK mode, does the mpc allow you to scroll through the cd? In what format are the samples. If the sample doesnt load, it wont play, but when selected, it should allow you to preview the sound. The 4000 allows users to import/load SND and WAV files.
The MPC4K should allow you to sample right out the box, but make sure you have the latest OS.
http://www.akaipro.com/support.php
try the 4k FAQ..
http://www.akaipro.com/supportfaqsMPC4000.php
It's also covered in the manual with you can download for free @
http://www.akaipro.com/supportdocuments.php#Z248
I know, who wants to hit a manual when you want to bang out....I'm a classic 2K owner, trust me I know, but sometimes the 5 minutes in checking the methods, saves you downtime, and gets you into funk mode quicker..
The 4k is also the first Mpc to come with onboard sounds, so check a preset, then check your cd, and if youre getting audio from the preset, then you know it's not the sound generator / synthesis chip. If you have a computer, try itunes or sound converter to switch the sound format, or look for a really nice low end application called CDXtract.
If youre banging out on halloween, youre my kinda MPC user.
Keep me posted.
Oct 31, 2007 | Akai MPC-4000 Plus Production Center (w/80...
(Mpc 1000) Only right Channel Produces sound
Are you recording, writing, sampling in mono or stereo?
Oct 17, 2007 | Akai MPC-4000 Plus Production Center (w/80...
Computers & Internet Logo
161 people viewed this question
Top Akai Computers & Internet Experts
Alun Cox
aravind shet
aravind shet
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
