see this causes and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum.
When these rollers are worn, they can be noisy. You should replace the
whole set of rollers at the same time. You will need to
disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our
videos for other style dryers.
Belt
The Belt should be replaced if you hear any noise coming from it
or if there is any cracking, glazing, or grooves worn out.
Replace the Belt along with the idler pulley.
Idler pulley
Dryers have a tension or
idler pulley
that keeps tension on the main drive belt. When it's worn, it can be
noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the
clothes drum for support. When these are worn, they can be noisy. When
that happens,
replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center
spindle instead of rollers. The spindle may be a ball-and-socket type
support or a shaft through a sleeve. When the components are worn, they
may squeak, squeal, or rub. You can't repair them. Just
replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This
video walks thru another type.
Blower wheel
Your dryer's
blower wheel
pulls air over the heat source, through the clothes drum, and past the
thermosta ts, then pushes it out the exhaust duct. The blower wheel,
which is usually plastic, may wear out over time. But if it's noisy, it
may simply be clogged with lint. Clean the blower and test to see if
the dryer is still noisy. If it is, you probably need to
replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy
replace the motor.
