Question about Garden
Difficulty starting mower. When I prime with plunger, I don't hear/feel gas sloshing like usual. Housing to air filter was on crooked so replaced air filter. I took apart from fuel line to carburetor and cleaned everything well. Ckd spark plug...it was fine. I got it to start once but running too fast. Adjusted linkage rod, then way too slow (trouble keeping it between 0 and 100). Priming still feels wrong. Finally got it started. Each time it takes a lot of cranking to turn it over (electric start). In fact, I had to recharge and it was just charged up.
  • 4 more comments
  • Sheila Johnson May 21, 2011
    What do you mean by worse (first sentence)?
    What did you mean by "or worse"? Still with the carburetor or something else?
    I have rebuilt the carburetor with an overhaul kit and toluene. I have struggled with the idle timing. I have trouble keeping the mechanism in place. It vibrates to either 0 or 100. It did start fairly easily today after I recharged the battery. Running fast though.
    Could the plunger be bad? I haven't noticed anything on a quick glance. Even now that it occasionally starts, I don't hear anything when I prime. I really miss those old mowers with a choke and idle/speed adjustment on the handle bar :)
  • Sheila Johnson May 22, 2011
    I have seen cracks in the fuel line but no gas leaking so I assumed it was still okay. "I'll replace it next time" syndrome. Sounds like the air could be getting in there. I'll replace the above. I found my carb overhaul kit that I ordered last fall so I hope to get it in good shape. Thanks so much for your help! I'll fill you back in after I get the parts.
    Very helpful. I have been chasing around this issue for 2 seasons now...needing to tweak and clean carburetor every few mows. I knew there had to be something else. Thanks!
  • 5,370 Answers
Replace the primer bulb and check lines for cracks. They fail over time causing the fuel to not be delivered to the carb. Also check gas lines to make sure there is no crack, check the bulb and check carb gasket.If their are any signs of cracking in any of them, replace them... whats happening is somewhere air is getting in and displacing the gas, not allowing for a good suction. Check the plunger if its cracked or bent it can be the issue.Also check the fuel line and vents.If its clogged or cracked it can cause such problems, ------- This should help.Thanks.Helpmech.
Posted on May 21, 2011
  • raj somaiya May 22, 2011
    Yes that should help.Keep updated with the results.Thanks.Helpmech.
  • 1,940 Answers
It sounds like you may have a clogged jet in your carburetor, or worse. I would start by removing the carburetor and replacing it with a new/rebuilt one, or taking it to a mower shop for rebuilding.
Usually, a replacement carburetor for a mower will cost anywhere from around $50.00 to $100.00. Having a shop rebuild yours is much less, and buying a rebuild kit for you carburetor costs even less. Rebuilding your carburetor involves using solvents for cleaning, removing and replacing tiny parts such as springs, clips, etc., and readjusting idle screws, valves, etc. I would recommend having a professional shop rebuild your carburetor, or replace your existing carburetor with a newer, redesigned carburetor.
  • Jeremy Moore
    Jeremy Moore May 21, 2011
    Your valves could be out of adjustment, but I am betting it's the carburetor. Hard starting, and difficulty priming deal primarily with the carburetor.
Husqvrna hu775h wont start
Suggest start w/ the basics : Air, Fuel, & Spark. Internet search indicates that it's a Briggs & Stratton engine, which I just worked on yesterday (165 cc version). Easiest things first - ensure that there is FRESH fuel in the tank. If it's been sitting there all year, drain it out and refill with new fuel. (make sure you follow mfgr's recommended fuel type.) If you have a primer pump, make sure you can hear fuel flowing when you depress it (typically 3 - 6 pushes to prime the engine). If not, then youi may have a fuel line or fuel filter clogged. If you remove cowling/covering over top of engin, you can get access to the air cleaner. Remove the air cleaner/filter, and you can see into the carbuerator. This should make it easy to see if the primer pump is squirting fuel when depressed. While the air filter is out, make sure it is clean. If gunked up, I usually soak it and wring it out in fresh fuel, then let it air dry to clean it out (mine is made of foam). If it's a cartridge type air filter, blow it out w/ compressed air, or put a new one in if it's dirty. Lastly, if you have an assistant, you can check to see if you're getting a spark. Remove the spark plug, inspect if for correct gap and overall condition - remedy if you see something wrong. Then with it out, connect the spark plug cable (the high voltage line) to the top of the plug. Now, while touching the threaded part of the spark plug to a bare metal part of the engine case or lawnmower chassis, have your helper pull the starter cord and look at the plug's gap for a series of sparks.
If you don't see any sparks jumping the spark plug gap, you may have a bad plug, bad cable, too big a gap, or a bad magneto, or corroded connection to the top of the plug.
If you don't have fuel flow, you may have a clogged fuel line or fuel filter.
Air flow is pretty basic, so with the air cleaner removed, it should be pretty obvious if you have an airflow restriction. You can leave off the air cleaner/filter to troubleshoot the engine and to start it, just don't operate the mower without it, or you risk sucking in junk, rocks, you name it, into your engine.
THis may go without saying, but also inspect all linkages, springs, cables, etc. IF you see something loose or broken, check the owners manual or diagrams and remedy that. Also check out the Troubleshooting section in the owner's maual (available on-line at Husqvarna)
My problem yesterday was very simply BAD, OLD GAS. Briggs & Stratton make a pretty reliable, easy to start lawnmower engine. But even that's not enough if you're feeding it bad or contaminated gas.
Aug 11, 2012 | Garden
Ai put oil/gas mixture in tank...drained tank put correct gas and cleaned air filter..will only start after prime but only for a second
You've probably plugged the carburetor up with oil. It'll need a good cleaning with carb cleaner. If you don't know how, then I'd recommend a professional to do the job. Best of luck to you.
James
Aug 20, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Changed the oil and fuel filters in 06 duramax and truck won't start
IS THE ENGINE TURNING OVER? IF IT IS YOU MAY HAVE TO BLEED AIR FROM THE FUEL SYSTEM, IF THERE IS A MANUAL PRIMING PUMP, USALY BUILT AS PART OF THE FILTER HOUSING OR REMOTELY MOUNTED ON THE FUEL SYSTEM PUMP THE PLUNGER THILL IT GETS HARD THERE SHOULD BE A BLEED SCREW MOUNTED OPEN IT AND STROKE PLUNGER UNTIL YOU SEE BUBBLE FREE FUEL COMING THROUGH CLOSE OFF THE BLEED SCREW AND PUMP PLUNGER TILL HARD AGAIN THEN TRY STARTING
Jul 29, 2011 | Chevrolet 2500 Cars & Trucks
Changed the fuel filters on the truck and can't get it started.
by saying filter(s), i assume this is a diesel engine
The filters must be filled with fuel prior to installing them, that will induce air into the system and will not allow for fuel to flow
Once filters re installed with fuel in them, there should be a plunger you can prime the system with on the filter housing, if you still have issues of starting you can use JUST a little quick start while someone trys to start the truck.
Good luck
Jay
Jun 24, 2011 | 2006 Ford F 350 Super Duty
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
2003 Chevy Duramax 2500 HD with a vapor lock when temp is moderately hot; will not start without using prime pump on top of fuel filter housing - sometimes with low fuel level will not re-start even with...
Most likly the filter housing needs to be replaced and or the fule lines to and rom the housing. the housing has the plunger on top and the filter screwed under. The plunger goes bad on these and causes air to enter and then become air locked. this is also very comon on the IPR with the fuel filter housing mounted behind cab on frame rail driver side. road sault gets to these and degrades the unit untill it sucks air. On the c 4500 you need to get the oem fuel lines because of the tight space restrictions to route the lines. the OEM lines are molded to make the tight bends required.
Hope this helps... Good luck
May 26, 2011 | 2003 Chevrolet Silverado 2500HD
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Mower will not start,changed plug,new gas,has fire to the plug still will not start,backfires once in a while checked the fues it is ok,it is a lx460 mod# 13AX60RH744, cleaned the points etc,
Replace the air filter. Remove the plug and try to start it. If you don’t smell the gas your problem is fuel. Most have a primer button that needs to be pressed 3 times. Remove the air filter and press the primer button to see if you squirt fuel. If it has no or little smell, continue priming and starting until you have fresh fuel. Replace the filter and plug. Disengage the pto ect ( saftys)before starting. Here is the manual Don’t forget to follow the safty startup list.
http://www.dixiesales.com/ipl/339/13ax60rg744_operators_manual_02_22_06.pdf
Aug 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
