I have a purex triton minimax 150m heater and it starts and runs fine but it shuts off when the water is still cold. I have it turned all the way up but it still shuts off to soon, the pilot is still on just does not want to keep going. Thanks for the help
burzerko
  • 254 Answers
SOURCE: My pool heater pilot will
Ok a couple things to check here would be a thermocouple or a flame switch depending on the the type of ignition source. If it has a standing (continious) pilot you need to look for a small copper line returning from the pilot source to the gas valve most likley this will be it. The other will be a small copper line returning to a switch with 2 wires on the backside this will be a flame switch. the thermocouple could most likley be purchased from your local hardware store but a flame switch will have to come from the heater manufacturer.
Posted on Jul 01, 2008
  • 143 Answers
SOURCE: when i turn the hot
Air conditioners do not provide hot water, and gas air conditioners are very rare. I think you would have better results if you post this in a different category.
Posted on Jul 27, 2008
pierre1811
  • 144 Answers
SOURCE: Furnace pilot light turns on furnace lights then shuts off
If you have a hot surface igniter (glow coil) it has a secondary purpose after ignition and that is to sense that there is actually flame present. If the HSI is located on one end of the burners look to the other and see if there is a small rod that protrudes in to the flame as well. If so it is part of this flame proving cycle. Take some sand cloth and clean it. This may buy some time but the rod should soon bee replaced.
Posted on Jan 17, 2009
  • 139 Answers
SOURCE: The pool and spa heater, purex triton, show a code
sounds like flame sensor is dirty,they rarely go bad.remove and clean with steel wool or fine emory cloth
Posted on Jun 21, 2009
  • 7 Answers
SOURCE: pool heater won't kick on
check the gas line pressure; (if this was a homeowner installation you will not be able to check the gas pressure) dirty filters are the number one cause of heater malfunction. before you do anything else break the filter apart and clean completely and recharge with diatomaceous if applicable. also check the pump baskets and make sure there is no debris in the basket or blocking the impeller inside the pump. if this doesn't solve your problem call pentair tehcnical support
Posted on Jun 25, 2009
Triton Purex minimax 400
dan i belive you have a faulty thermastat switch
Apr 01, 2012 | Pentair MiniMax CH Natural Gas Pool...
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Purex Triton Minimax 400 pool/spa heater not igniting
This sounds like you have a problem with your pilot. You can check this with a small mirror to see if their is a spark when you turn it on. If you have any soot build up on the pilot that will stop the spark and keep it from lighting also. If you have a short on your pilot wire this could be the problem also. I hope this helps, good luck.
Jun 05, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
