Question about Microwave Ovens
My Kenmore ULTRA WASH Dishwasher is suddenly DOA as I got to start it today. There is water left in the bottom from the last run and nothing is lighting up. I've checked the circuit breaker, GFI's and the manual. Help!!
  • 2 more comments
  • rileybreccan May 21, 2011
    Ok, I have the access panel off...not sure where to go next
    Is it a possibility that this drain pump is bad? Is that a common problem?
  • rileybreccan May 23, 2011
    It was actually the safety stat. The dead machine had absolutely nothing to do with a drain issue.
    Not helpful at all
  • 4,323 Answers
Hi
It seems that something is blocked in the drain pump assembly resulting in a dead unit. Pull the bottom front panel out and clean the drain pump assembly, after this it should work, if it does not then the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 20, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott May 21, 2011
    Check this video for cleaning:
  • Daniel Scott
    If you have cleaned it and the issue is still there then the control board should be checked and if bad should be replaced.
  • Daniel Scott
    Daniel Scott May 23, 2011
    In your case it isn't but usually I have seen that blocked drain hose causing this issue....anyways also told you about the control board
While dischwasher is running, water are leaking from the front.
Depending on the model, there are corner seals (kenmore are black) at the base of the door these can fail , Frigidaire, Galax, and Whirlpool/ Tappan use small plastic diverters that are semi clear.
If these are missing in the corners nearest the base of the door then this problem
will occur. Also if you are using regular dish detergent, it will oversuds. One last note,
if the dishwasher has not been used for a while due to handwashing on the disposal side
of the sink, the soap will make its way into the sump of the dishwasher and cause this
condition. Try using several pitchers of water and pumping out the water by rotating the
control knob till it pumps out to dilute the soap. Hope this helps.
Jul 17, 2011 | Microwave Ovens
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Is it best to clean a Teflon skillet by hand or can you put them in the dishwasher?
This is what Dupont the maker of the cookware coting has to say about cookware care:
2. "What is the best way to clean my nonstick pan?" Simply wash with hot, soapy water after each use. A sponge or dishcloth is usually all it takes to get the surface thoroughly clean. If oil or food residue is left on the pan, further cooking will harden the residue and cause sticking over time. For pans that have "carbonized"-where a thin film of oil has baked onto the pan-we recommend you use a little more elbow grease when cleaning in order to break through this layer. Future cleanings will be as easy as with new.
http://www2.dupont.com/Teflon/en_US/products/qanda_cookware_care.html#careq2
Nothing about a dishwaher in the above. It appears you should wash it by hand.
Thanks for choosing FixYa,
Kely
Jun 19, 2011 | Microwave Ovens
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Hi I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3...
    I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3 and nothing else works.
    In order to start it again I have to switch off the power and start all over again.
    Please help me in fixing this problem
    Oct 28, 2010 | Microwave Ovens
    I need to reset my Kenmore Elite dishwasher but i don't know how.
    follow the below instructions:
    Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
    Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
    Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
    Good luck.
    Jul 14, 2010 | Microwave Ovens
    I have a bosh dishwasher that has not drained of water and the tap light is red on the indicator board
    Hello there:
    Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
    If the motor isn't turning or working, the unit won't drain. Some dishwashers are susceptible to getting stuck if you don't run them regularly. I you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
    Jul 08, 2010 | Microwave Ovens
    Microwave Ovens Logo
    35 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
