Send it back to Kodak, these models are nothing but trouble, far to many customer complaints, Made in China and not made very well, not dependable, Try a better brand. Kodak has seen better days with their products. Buyer Beware
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
First, stop plugging it into the computer. Next, remove the card and battery, press all the buttons, leave it alone for 20 minutes, insert the card and then the battery (which I'm assuming is fully charged), turn it on. To download your pics in the future, use a separate card reader.
This just happened to me last night. Literally, the EXACT same thing. Here's the sollution:
Wait 'til your camera has run out of chage, it will then turn off. The camera lens will still be sticking out, though. Once it has turned off, take your charger, plug it in, and then charge your camera. Once the charger is actually in the camera itself, it will turn on and resume its' normal mode. :)
CALL DIGITAL POWER PRO @ 801-934-6269 OR GO ON-LINE TO DIGITALPOWERPRO.COM,
THEY SHOULD BE ABLE TO HELP YOU. I BELIEVE YOUR BATTERY IS COMPATIBLE WITH THE FUJI NP40
This should be a problem with your memory card......
If you are using a Memory Card try to use a smaller size memory card.......
If you are not using a memory card then thats a problem with the camera itself........
Good Luck.....
It sound like a problem with the zooming mechanism, does your camera was dropped down ?
In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem.
