Question about Syntax Olevia 527-S11 Television
We are having problems getting channel 3 on our Olevia television. We have Dish, and chatted with them and they suggested that it was the # 3 channel and 4 were not programed in. I tried to call Olevia and they are no more. Do you have a suggestion on how we might program # 3 channel and # 4. Thank you. Marya Mather
  • 11,361 Answers
I cannot locate free user manual for your TV, what you need to do is to go into the TV Tuner setup menu and have the TV rescan for the TV signal, it should pick up the Ch3 or Ch4 signal from the Dish box (depend on what the Dish box RF output is set to 3 or 4).
I myself will not use the RF output of the Dish box, I would have use the Composite video out (Yellow RCA jack) or Component video output of the Dish box to get the best pictures which the Dish people should have recommend you to do, the Video out put of the Dish box will feed the AV1, AV2, Component 1, 2 depend which you have available. You should also be able to punch CH3 or 4 on the remote control for direct access.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on May 21, 2011
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I can not find the channel for Dish Network.
This hopefully is resolved for you, but here are some easy steps if you ever run into this problem again. If you are at TV1 where the receiver box is located:
You want to make sure that the tv is on channel 3 or 4, and usually on an input. Since the tv says Channel unavailable, it sounds like you do need to be on an input. Try video 1 or 2, or cycle through your inputs.
If you are at TV2
You will want to make sure that your tv is on channel 60 or 73, and you will want to make sure that the receiver box has 3 lights on the front. (Blue, green, yellow.) You will need all 3 lights ont he receiver box for the TV2 to show a picture. I hope that this helps.
Becki Barned
Jul 12, 2010 | Olevia LT27HVX 27 in. LCD Television
Cannot get all channels as other tv`s.
is there cable / sat dish connected to this olevia 23? if so or you need is ch 3...and cable/sat box will be ch selector....but if not this is what you do go to menu setup and select scan tv for channel (if on air..ch 2 -67 or so...if you select cable broadcast it should go from 2 - to hundreds)
Jun 01, 2010 | Olevia LT23HVX 23 in. LCD Television
Firmware upgrade and lost all channels
How are you getting your channels,cable,dish,air? Your best bet is to go in and rescan your channels.
Nov 01, 2009 | Syntax OleviaL 527V 27 in. LCD Television
Will NOT acknowledge one channel
This problem was already posted by someone else and they were having the same issue as you.. they said that they contacted FOX engineers via email and they emailed them back stating there was a problem on there end and with in the next day the channel started to show up on the Olevia television.
Seems like FOX has changed there frequencies and some television were having trouble picking them up.. depending in the area..you might want to try contacting them in regards to your problem to see what they suggest..
Jul 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Olevia 237 with satellite dish
I purchased a universal remote URC-R6 from Best Buy that someone else had said worked for them. With a little work, I have programmed it to take the place of both my remotes. Seems to be working fine!
Aug 23, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Syntax Olevia 527-S11 Television Logo
189 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
