Question about Dishwashers
When I turn my dishwasher on, the motor runs, but no water comes out. Last night I did a load and this morning there was water all over the floor. Lynne
    Problem Solver:
  • 6 Answers
Simple things first
Is the pump discharge hose still connected.
Pump impeller housing broken/ pump impeller housing discharge nipple broken
Hole in ye old hose.
Rusted out tub??
and the not so obvious is the water comming from somthing else and the pump on your d/w is just not working. water is dangerous can cause fire when in contact with electricity
Posted on Aug 15, 2008
WHY DOES THE MOTOR ON MY SAMSUNG DISHWASHER RUN ALL THE TIME AND THE LIGHT ABOVE HEAVY BLINK?
Yes, you've got a leakage error, which means water has leaked down into the base of the dishwasher. The drain pump runs all the time, trying to get all the water out, but the drain pump can't get to the water down in the base. (Those North Korean engineers/designers aren't too bright.) You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water before that drain pump will stop running. But you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Feb 24, 2015 | Samsung Dishwashers
665 dishwasher
If the door is not locking properly there is a chance that the door lock switch is not being closed. This will shut off power to many of the circuits, including power to the water fill solenoid, etc. Latch mechanisms are available separately.
Sep 19, 2017 | Galaxy Dishwashers
I have a Bosch SHU3036UC dishwasher. While sitting idle - during the day or over night, it fills up with fresh water. I shut off the water supply last night and this morning it was dry. Any ideas?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 12, 2011 | Bosch SHU3036UC Dishwasher
DW5700P1 dishwasher must have stopped running last
A lot depends on at what point the dishwasher stopped working.
Have you tried to turn the mains power off and on again and then try one of the short cycles.
I would suggest if water is not draining, then empty with a small pan and check filter for blockages. Also good idea to check there is no blockage on the drain side.
A good site to check is
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Please post a comment to let me know what you find.
May 29, 2010 | Frigidaire Dishwashers
Runs too long
the water going into the unit needs to be 120 degrees for it to work correctly. the D/W is trying to heat the water up to 120 degrees. it will heat a degree a minute. depending on what the temp is in the washer. try turning on the hot water first before you turn the dishwasher on. verify that the water is 120 degrees coming out from the faucet.
Oct 19, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwasher worked fine last night, this morning it is not working
In some supply systems, there is a safety valve ( commonly referred to as a shuttle valve) that has a small ball bearing that blocks the water from flowing if a water line bursts.. This is supposed to be a safety feature to prevent flooding but can be an annoyance if that ball moves and blocks water flow from coming in.
That, or your water inlet valve may be the prime suspects for this problem..
Hope this helps,
Regards,
Rick
Dec 13, 2008 | Bosch Dishwashers
GE Profile PDW8800
Try replacing the water inlet valve.
Nov 12, 2007 | GE 24 in. Profile PDW7800 Built-in...
Ultra Wash
Sounds like your not getting water to it. Turn on and let run for a few minutes then open door and check to see if you have water in it.
If not check to be sure water to it is turned on. Check float in front corner of dishwasher to see if moves freely up and down and that there is nothing underneath it. If these check ok you probably need a water valve.
Nov 03, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door gasket.as far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Indesit Dishwasher
disconnect the drain hose and lower it into a bucket if no water comes out there is a blockage in the hose/pump.
Jan 25, 2007 | Indesit 24 in. D63S Free-standing...
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
